Before I install this on my car please check my work
Ok so I have chosen to do the zip tie mod.
I plan on replacing the zip ties with bigger, better ones and a new air filter as soon as tommorow. But do I have the concept down?
Here's the DIY
https://www.corvetteforum.com/articles/c5-intake/
How does this look
Here's the DIY
How does this look
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ok so I have chose to do this mod.
Here's the DIY
How does this look
Here's the DIY
How does this look
OK,,,,,,,,,,,,,,,,,,,,,,,, The main goal with an aftermarket filter/Housing is MORE AIR and COOLER AIR.
You "WILL" get more air,,,,,,,,,,,, "HOWEVER" it may NOT be cooler air. Cooler (more dense air) increases HP. Without isolating the engine compartment from the filter, you will be gulping OTHER THAN TRUE COLD AIR.
My recommendation would be to install a VARARAM and be done with it.
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On a side note,,,,, This is the MOST cost effective FREE mod that you can do. If you like the improvemant,, just keep what you have.
Bill
Bill
Bill
Bill
Eventually I do plan on a vararam.
Thanks for your help bill. You were a life saver when I was having my voltage issues.
In addition to the Zip tie mod like you show, you can do a cold air version of it by flipping it over.
Take a look at the following link for another version of the zip tie that is a cold air one.
https://www.corvetteforum.com/forums...m-diy-yes.html
