Strong exhaust smell at idle
When sitting in traffic in my c5 coup, I get a really strong exhaust smell. Dosen't appear to be any exhaust leaks. I've searched this and haven't really found a clue yet. Is there a common issue that's causing this?
Not sure about the cats yet. Maybe there is a leak and I guess I won't know for sure until I get my '98 up in the air.
Really, the fumes are so bad, they about run you out of the car.
Has it always been this way or recent development?
I've had it about 2 months. Wish I could answer your question for sure, but I don't recall this during test drive or soon after I bought it.
As far as fuel goes. I've filled up several times at different stations and problem is consistent.
Looks like.... or smells like..... I have found the problem. I had been getting the P1416 code, so I retrofitted the passenger side check valve. Took care of the code and the exhaust fumes in the cabin as well. My guess is the check valve was stuck open allowing exhaust back through the valve and leaking out the hose connections for the AIR circuit.
