DextronIII vs Dextron VI
8th Gear
I've had conflicting answers on whether or not Dextron VI is suitable for the 99 C5 standard transmission. Can anyone advise
Thank you
Thank you
Btw, it's "Dexron".
Here's the official word on it..
Originally Posted by GM #04-07-30-037D
MANUAL TRANSMISSIONS / TRANSFER CASES and POWER STEERING
The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRON®-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid. Power Steering Systems should now use P/N 9985010 labeled Power Steering Fluid.
Consult the Owner's Manual or Service Information (SI) for fluid recommendations.
Some of our customers and/or General Motors dealerships/Saturn Retailers may have some concerns with DEXRON®-VI and DEXRON®-III Automatic Transmission Fluid (ATF) and transmission warranty claims. DEXRON®-VI is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON®-III and/or prior DEXRON® transmission fluids. Please remember that the clean oil reservoirs of the J 45096 - Flushing and Flow Tester machine should be purged of DEXRON®-III and filled with DEXRON®-VI for testing, flushing or filling General Motors transmissions/transaxles.
DEXRON®-VI can be used in any proportion in past model vehicles equipped with an automatic transmission/transaxle in place of DEXRON®-III (i.e. topping off the fluid in the event of a repair or fluid change). DEXRON®-VI is also compatible with any former version of DEXRON® for use in automatic transmissions/transaxles.
Dex VI is not compatible with Corvette manual transmissions.
* GM Manuel transmission fluid (listed above)
* Dex III from the parts store (I am running Valvoline DexIII) (amsoil and mobile are Synthetic, off the shelf Dex III at the parts store may not be)
S
S
8th Gear
Dexron VI
So, the short answer from the quoted service bulletin; is that Dexron VI is "OK" for automatic transmissions but not "OK" for manual transmissions?
Does that make sense?
Dannyman
Dannyman
I've been running the Dexron IV in my 99 FRC now for over a year with no problem, fact is the car shifted better when I went to the new fluid. I was advised by a retired Corvette GM engineer (here on the forum) that the Dexron IV was fine to use.
You might want to read this:
https://www.corvetteforum.com/forums...-vs-dexvi.html
8th Gear
It's not confusing at all. It relates to where if synchromesh (88861800) is not available, it says use DexIII, but do NOT use DexVI in the specified transmissions.
Now you're entertaining a dealer's, contradiction of the very document GM published which, by the way was published at the time, primarily regarding certain Cadillac, Hummer and Saturn models with manual transmissions?
Your car, your call. Good luck.
There have been multiple discussions of manual transmission fluid usage, here on the Forum. The differences hinge on the earlier transmissions having "paper blocking rings" that are not compatible with synthetic transmission fluid, which Dexron VI is......
(Dexron III is not synthetic)
My previous post was not clear enough to re-state what has been said throughout this thread.
The answer provided in this thread; and supported by the GM Bulletin, is that Dexron VI should not be used in a standard/manual transmission. It goes on to state that Dexron VI can be used in the automatic transmission.
Is it possible that when stating in his original question, "99 C5 standard transmission"; he was referring to his standard transmission being in fact an automatic?
Dannyman
Premium Supporting Vendor
If you have an automatic, then the newer dexron VI would be suitable, but I personally would still use an aftermarket dexron III as the dexron VI has a lower viscosity then the dexron III and I'm personally not impressed with the basestock performance in dexron VI. Like many fluids, the dexron VI was introduced to lower viscosity, lower friction and improve GM's net CAFE (fuel mileage rating).
For what its worth, I use this in my manual:
AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
8th Gear
Hi folks. I do have manual. I've been to 4 GM Chev Olds dealerships in my area. Three say Dexron VI and one said GM Manual transmission fluid . I've contacted GM directly and got no response.
Thanks for the bulletin
Anyone have any idea why this bulletin says it does NOT apply to manual transmissions?
"Originally Posted by GM #04-07-30-037D
The content of this bulletin does not apply to manual transmissions or transfer cases."
Also, I would like to understand the "paper blocking rings" statement. Any paper based product would last about 5 seconds in a gearbox. Blocking rings take a beating, and years ago sintered iron was commonly used.
My '98 C5 has had Mobil 1 synthetic ATF in the 'box almost from new and at 75k everything works fine. Only "issue", if it called be called that is the shift is in fact a bit smoother and easier when the 'box is still cold. I may try dino oil next time. Wish it would shift like our Subaru which runs 75/90 in the front transaxle. I use Delvac, and the shifts are buttery.
Mine is an early enough C5 (delivered 9/97) to have an actual Borg Warner built box. Any difference there I wonder? Though everything I have read says Tremec made the boxes exactly the same as the originals.
