intermittent rough idle
HI, new to the forum, first post and 1st vette. I just bought a 1999 LS1 6spd w/83000mi. My concern is an intermittent rough idle, it idles smooth for about 5-10 seconds, then shakes for a couple of seconds, then smooths out again then repeats again. The car pulls hard no skips or anything. There are no codes in the computer. I see no broken vacuum lines. Any info or advice would be appreciated
Makes a big difference.
THANKS for the input, will do tomorrow. GREAT forum, plenty of info.
He said it was a good thing it came that way, because as he replaced the elbow, the next piece broke, as he replaced that section the next section broke, etc, etc. The whole thing was so brittle it was falling apart as he removed it.
Mine was not idling rough, but would drop to 400-500 when I came to a stop, then the computer would bring it back up to 600-700. He said he was surprised it wasn't throwing lean codes and I said it had just started to, occasionally. I knew my Long Term Fuel Trims were WAY up, too. After replacing the PCV and tubing assy, now my Long Term and Short Term Fuel Trims are back near zero.
It's amazing how the computers can compensate for / mask a problem. I just passed California emmisions several months ago, with a vacuum leak big enough to force the LT Fuel trims to max out. By the way, this is a 203,000 mile LS1.
Steve
