pull the motor or just add heads an cam???
Hey guys,
I have a 2001 6 speed car with 115K miles. I am not currently having any problems with the car. I am contemplating doing some engine work. I do not nor do I plan to do any racing, Just want a good weekend car that turns heads with a good lopey cam.
My concern is with the miles on the car. I think I would be more comfortable if I had he motor pulled and completely went through to hopefully ensure I'm not going to have any issues down the road. Am I being too overly cautious?
Thoughts?
If I would pull the motor I am not necessarily looking to go bigger unless of the course the money doesn't go up to much. What type of ball park prices should I be expecting?
thanks in advance.
Thoughts?
thanks in advance.
Technology has come a long way. Heads and a cam will give you a long lasting car if you drive it right. Check out the cams REALLY well. I wanted a lopey idle, installed a cam with 112 LSA, but also wanted it to still pull from low RPM. I got a few HP boost, but not much lope. I was disappointed. Now when I put my Maggie on there it's a different story. But a much larger drain on my bank account. I don't care. Getting smashed back in the seat at 40mph in 4th gear when I put the pedal down rocks!!
St. Jude Donor '14
If the engine has been well maintained, your good to go. Is it quiet, no smoke? Good oil pressure? You could easily pull a valve cover. If it's clean in there, go for it.
This thread will put you at ease.
https://www.corvetteforum.com/forums...o-on-a-c5.html
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WELL,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, When you UP the power, other things start showing their weaknesses.
For example:
Torque tube bushings and bearings.
Clutch/ clutch hydraulic system
Differential limited slip clutches and clutch plate Belleview springs
There is a BIG list of mandatory replacement parts that you have to purchase and if you want to do the job the BEST it can be, you should up grade to better replacement parts. Example:
ARP Head studs
ARP damper bolt
Ported OEM oil pump or a Melling pump
New damper Aftermarket is much better than stock
The list get bigger,, trust me.
Good luck!
Bill
So,,,,,,,,,,, This is going or could be a bigger investmant than you planned for.
TRUST ME! I know well!
Bill
For example:
ARP Head studs
ARP damper bolt
Good luck!
Bill
Bill
Well, being a relative newby to this whole deal of performance engines, I certainly appreciate the feedback. Bill's information is exactly what I am looking for. The last thing I want to do is do something now and have to pay big later. I greatly prefer to do work that makes the engine better and not do anything that will make it a ticking time bomb. Ok, I know I may be a dramatic when I say that
But I really only plan to spend no more than 4k. But I want that money to be the best bang for my buck that I can.
Received 3,043 Likes
St. Jude Donor '05
Miles are miles
Dont kid yourself if you do a H/C you WILL be stepping on the loud pedal and it will be taxing that bottom end. Just do it right and not worry about it.
Not everyone has a lot of money to through at parts that can or could fail.
110k miles is fine for these engines.
You said you are not going to drag race it every single weekend.
If you are also not going to pull the heads every 6 months you don't need the head suds.
Yes they are great to have, and if you have the money get them. If not don't worry about.
As for the oil pump... did the one in it get you to 110k miles.
A cam and heads will not effect the oiling of the engine. Sure if you rebuild the bottom
end and you race the car, or you spray the car, or you do something needing the
additional oil movement then sure get one. But a simple head and cam swap for a street
car does not require one.
Its an LS... if the engine goes and you don't have the money for new one go to a
junk yard and get another one with 100k miles on it.
Remember most corvette guys simple adore there cars and want the very very best for them.
Check out some racing forums and see how hard you can really punish these engines.
Everything you have been told is good advice and you would benefit from all the parts mentioned.
Is you car going to blow up if you don't get them? No.
If you car does blow up it is not from a lack of those parts, it is from other unknown issues in the engine.
well I have asked cincy speed to provide some pricing for a heads/cam package. The numbers haven't came back yet, but I am leaning to just doing that.
