Cant get into first or reverse, clutch problem
#43
I thought about sending it away to a vette shop but I've taken this damn thing apart so many times now that it's personal, I can't let this car beat me. Does the shop know for certain it's the clutch? Or are they going to do some troubleshooting for you?
#45
Imput shaft
Check the straightness of the splined imput shaft. It may be hanging up on the pilot bearing causing the drive shft to spin. I tried Arp fasteners on my monster stage 2. They were so tight going in I thought I would strip the threads in my fly wheel. Went back to GM bolts.
#46
Thanks for the help guys, I went ahead starting pulling the old clutch to put in the new one and springs from the clutch disk started falling out. Guess I found the main problem. Looks like one set of springs fell out and started tearing up the others. No damage to the flywheel though.
#47
cars back up and running but I got a side question would it be worth it to have the lightweight flywheel turned and try to sell it? what would I have to do to ensure it is reusable?
