Cant get into first or reverse, clutch problem
Well I just got done changing the slave cylinder and clutch master cylinder and I'm still having trouble getting into first gear or reverse. Actually I can't get into them at all. It still feels like the clutch is not fully disengaging. I've bled the system the normal way and with a mityvac. Any suggestions on where to go from here?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
With the ENGINE OFF,, Can you shift normaly?
Jack up the rear wheels and put the car in first. Start the engine and see if the rear wheels are being driven when you depress the clutch. If you cant STOP the wheels from turning, you have a disengement issue. Do reverse and all the rest of the gears
Bill
Bill
With the car off I can get into all gears, when I start the car in first the wheels start moving same for all the other gears. When I press the clutch in they still move. Any ideas? Like I said earlier new slave and master, I bled two bottles of dot 4 through it, pedal feels fine just not disengaging enough? If that makes sense.
How many miles on the clutch setup that is on it now?
I have the issue with the clutch pedal sticking to the floor when I am going wide open throttle. Supposedly an aftermarket clutch will solve that issue.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the wheels are driving with the clutch fully depressed,, the CLUTCH and FLYWHEEL are not properly disengaging. If you drive it like that, you will destroy the synchros.
If you have NOT bled the clutch with the bleeder, you may not have all the air out and that would or could cause this issue.
The NEXT thing that you need to do is properly bleed the system using the bleeder.
We can go from there
4drturbo
I was in the same boat with my 02 Z after adding 60+ HP. When I pulled the clutch out, it still looked good. Infact, little of no wear for having 45K miles on the clock
If it were me, I would change out the master and properly bleed the entire system like explained above and see if that helps.
If not, you will need a new master with a replacement clutch anyway. No cash or time lost!
Bill
I have bled the clutch, I installed a tick remote bleeder while I had the slave out, clutch is a monster stage 3 probably around 15k miles on the setup. So Should I continue bleeding? Slave and clutch master are brand new.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Once a clutch hydraulic system is properly blead,, its blead.
So,, It seem that the slave isnt pressing the pressure plate in far enough..
1. Was there a slave SHIM behind the old slave that you didnt reinstall??
2. Did you install the correct slave cyl and or the correct master??
3. Is there a gap between the TT and the bell housing??
4. Why did you replace the slave and master in the first place?
Bill
Bill
No shim before or after, yes ordered the parts from corvette central, no gap everything is tight, replaced because I was driving to work and all of a sudden couldn't get it in gear. Not driving crazy just cruising to work and bam, pedal felt fine but just not disengaging. No leaks so I figured it was the slave. Changed that but problem persisted so figured the master was next on the list. Still no dice, I did bleed it inbetween and after changing both components. Any ideas? Keep bleeding?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK,,,,,,,,,,,,,,,,,, Something sounds fishey under the dash. You have ALL new stuff but still didnt fix the issue.
Look at the clutch peddle assy, peddle rod and the mount for the master. Have someone depress the clutch and see if you see any flex or lost motion.
Bill
Bill
St. Jude Donor '14
What happens if you put it 1st with the engine off, hold the clutch pedal to the floor and start the engine? Make sure you have room in front of you and your right foot on the brake. Let off the brake and see if the car creeps forward.
Maybe the pilot bearing is seized?
Checked for flex none found, I pulled the exhaust and lower bell housing to check for leaks but no luck on that either. I had someone depress the clutch while I was under there and everything appears normal. Right now I've got the clutch pedal depressed I'm gonna check on it in an hour maybe there's a leak that I can't see without pressure.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
While you are under the car and have some help,, try bleeding the clutch from the bleed port on the slave cylinder one more time.
Bill
Bill
Kept bleeding it out and I consistently get 1 small bubble in the reservoir for every ten pumps of the clutch. Nothing comes out of the bleeder end. How long should this take in theory? To get a full bleed?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you pull a vacuum on the master cylinder,, does it hold? Ive never had any issues bleeding the air out of a few OZ oil system. Sounds like you have a leak somewhere. Have you tried tighting up the remote bleeder fitting on the slave?
Pull a vacuum on the master and cycle the peddle and see if you loose the vacuum.
Pulled a vacuum on the master today and it holds fine. I've torn down the car again to measure to see if I need to put in a slave shim other than that I'm out of ideas? Could it be the clutch is just toasted?
