Thoughts on TR6060/ C6 Diff swap
Is there any advantage at all for a street/ open track car making 450rwhp to "upgrade" to a C6 Z06/ ZR1 diff and TR6060, or would an RPM built MN12 T56 and RPM built 3-Rib diff with the cooling setup for each be perfectly sufficient/ comparable? I'm wondering primarily about bearing and gear longevity, whether the C6 will stay quiet for longer, etc. I have no plans to put this car on drag radials or even an ET Street so dragstrip discussion does not apply.
St. Jude Donor '14
If you get the right deal on a c6z setup, I would go that way. The diff and mounting arrangement is much stronger. If you not drag racing, you should be fine either way.
