Repair of Wilwood Brakes in Northern Jersey
I have the Wilwood big brake system on my 98 and have a right front calipher leaking. Can someone recommend a a good shop NNJ to service my system? Appreciate the help and thanks guys.
Joe
Joe
Former Vendor
If it's something as simple as a bleeder fitting they can be replaced very easily. If confirmed from the piston area you'll need a new "seal kit" and possibly a piston or two depending upon what is found at tear down.
Wilwood offers very affordable rebuilds so I'd inquire directly first as most shops you visit won't have the parts to do this and have to order them in anyhow. You can put it (them as I'd suggest you do both) in a flat rate box and off to CA for about $12.
Give them a shot first. 805-388-1188
