Installation of GM part number 19244028: steering column lock
Hi members:
I bought a GM kit 19284028 to install on my 2002 coupe that has had some steering lock issues. Unfortunately, GM didn't bother to send installation instructions and I have been searching the web trying to find something. Can somebody out there help with the installation of the GM part?
Thanks!
Thanks!
Uneducated overachiever
I'm not familiar with that part, but there is probably something in this thread: https://www.corvetteforum.com/forums...ky-please.html
Good luck with your fix!
That part number supersedes part number 89023816 (K harness). I think it goes under the steering column somewhere as opposed to the after market "CLBs" that go on the body control module but I cannot find an illustration to be certain of that.
K Harness is installed in series between the male connector from the lock motor and the female connector that goes back to the BC> Both are under the drivers side knee bolster.
K Harness is a complete waste of money. Your money and time spent resolving a C5 Column Lock issue would be better spent ordering and installing an LMC5. Google " Compliance Parts ". JMHO
You would do well to take this advice. 8VETTE7 is the recognized expert in column lock issues.
K Harness is installed in series between the male connector from the lock motor and the female connector that goes back to the BCM. Both are under the drivers side knee bolster.
Got mine here
http://www.complianceparts.com/c5collockdesc.html
video instructions too if you want them.
