Hoosier Torque Limiting Mount?
Hello all, this is my first post, I just bought my first Vette a few weeks ago and instantly noticed the massive driveline shake and hop when hard accel/burning out...definitely looking to fix this asap and with Pfadt being closed has anyone used the Hoosier mount? It looks identical to the Pfadt brace as far as I can tell, Any info would be helpful!
St. Jude Donor '14
Buy better tires before you break something. I'll think you'll find most of us don't use that mount. Make sure your shocks and suspension are in good shape. Check out dte trans brace.
Is there a specific reason not to use the mount? It seems like it would be a good investment to stiffen up the driveline and prevent damage to components
Trucker
I am having the HPE mount installed this week along with a rebuilt 3.73 diff. I have already installed the tunnel reinforcement plate and that alone tightened up the car a lot. I'll let you know what I think of the brace once I have it installed and light 'em up.
Ok thanks, keep me updated, I have a 2003 z06 thing bounces nonstop hoping to be able to install this myself over the winter if I hear it solves at least 50% of tranny shake
That "shake" breaks expensive parts. I've got both the ECS trans brace, and the Pfadt diff. mount. My first differential twisted itself into garbage hitting 4th gear @ redline. (before the braces/Rick Kim diff.)
How hard is it to install the ECS trans brace? I'm hearing weird noises when I shift from the rear, almost like the diff is moving forward and back against the trans?? Idk how else to describe it
Also how would you compare the Hoosier to the Pfadt mount?
The best part about all this is when I bought it at a dealer three weeks ago I asked why it was making that noise in the back when downshifting and when going from 3, 4, 5 they said "we inspected this car fully it was the service managers car and there is no mechanical issues, that noise is normal 'driveline slop' when the car gets older the mounts weaken and you get some rattling when shifting, it's nothing to worry about"....I never thought it was normal but I've never had a Vette before and know nothing about this cars setup :/
BTW, I think your dealer is FOS; nothing should feel loose, except the tires hunting for traction. Also, tire spin is the starting point to most cases of drivetrain shake, AKA wheel hop.
Here's the link with pics of the Hoosier version
http://hoosierpe.com/news/c5-differential-torque-limiting-brace-mount-available/
By your description I'd definitely need to drop the rear to get the ECS mounted then? No way to install with the sub and diff all mounted on the car?
And yes I also believe the dealer is full of it, I'm assuming he was trying to tell me that the noise was what gm calls Normal Backlash...I don't like the sound that's for sure
http://hoosierpe.com/news/c5-differe...unt-available/
Received 1,254 Likes
2016 C5 of Year Finalist
I use both the Pfadt and ECS brace and they work well together.
I have a lot of hp to control.
Did you use EPDM tape? I'm running a DTE brace, and Pfadt mount.
Edit: found more pics in the build topic.
Yes; between the diff mount, where it contacts the cross member. Also on the ends of the brace, where the large pads contact the cross; shim them so they're firm to the cross. Some guys have had vibration problems after installing this brace, but I didn't.
If you look at the rubber shoe on the end of the Pfadt diff mount in the pic below, you'll see where I added the EPDM pad between the shoe and the crossmember. I put one on each of the two shoes.
