Kooks headers leaking
I just recently installed some Kooks headers and they are leaking at the flanges. Anyone have any ideas how to get them to seal? Any ideas greatly appreciated not trying to have to pull these off as they were not the easy install headers I was told they were when I purchased them.
at the head flange? New gaskets? Torqued down?
I wouldn't assume anything. Everyone makes mistakes, maybe the installer got distracted and forgot to torque them down right, or maybe a new guy was on the job... Get yourself a torque wrench and check.
Is this new or second hand? If second hand you could try spraying some copper gasket maker on both sides of the gasket... Not the ideal solution but it may do the trick.
When you checked the torque, did you start at center bolts and work outward??
Headers
No dice getting these to seal up. Only option we are seeing is to cut them out of the car to install a new set. Any assistance before I go this option would be greatly appreciated.
Are soft aluminum gaskets available for the LS 1 heads? Some headers are flatter than others, for those that are not flat, cut the flanges between tubes, use soft aluminum or copper gaskets. At least for a traditional SBC that'd be my approach.
Before tossing them, if gaskets don't work, take them to a machine shop and have them mill the flanges flat if they are indeed warped. Shouldn't cost anywhere near that of new headers....
Headers
The issue with fixing them is getting them out. They are not the easy install headers. I am kind of over messing with them and want my car back. My car is a Z06 so I would need LS6 gaskets
