Trick for the telescoping switch for the column?
I have to replace my steering column covers because of brittle snapped parts, snaps gone, etc. The only part you can get now is in a shale like color- not gray but not tan either. I don't know why they couldn't come in Black -like the original?? I can deal- just get some good semi gloss spray black.
Problem is how do you get the telescoping button off and out of the lower half of the cover without snipping wires. I traced the wires back a ways, and it looks like they go back to a huge cluster of wires, with no connectors, although I could be wrong on that. The switch itself looks like a challenge to remove from the lower cover too. The manual says "remove switch" - big f'n help!
Any body know the trick here?
Best always,
Bluemill
Best always,
Bluemill
What I tried to do to color the GM part....
GM did the replacement steering column covers in a weird SHALE color, not gray and not tan either?? So I do the painting with satin black Krylon-one step, no primer necessary, thinking it will be duller than semi-gloss. It still is a bit shinier than the rest of the interior. I guess if I give it one pass of flat black- it may look closer. Why would GM make the part in shale any way? I bet that 2003-4 shale interior car had an all black column, and for that matter, I've never seen anything but an all black dash, steering wheel, and column in a C5.
Still waiting on what to do with the telescoping switch. Do you unscrew the tiny screws in the switch itself? Or, is their a very small connector for this switch deep under the dash? Hasn't any body been there?
Help!
Best always,
Bluemill
Help!
Best always,
Bluemill
