C5 Z - Failed Emissions - Question for the Forum
I have an '03 Z, heavily modified, 550hp at the crank. Fast, cam, AFR heads, headers, etc. etc. I failed the emissions test with high in HC and CO which indicates a unburned fuel - high air/fuel ratio. I know it needs a tune for various reasons - obviously this situation and an idle problem including surging. I am hoping the tune is enough to pass emissions testing.
My question to the forum is: What emission equipment is stock to a 2003 LS6 ? With the mods, it appears any standard emissions equipment has been removed. Did the '03 LS6 have an air pump? The emission test folks failed me for that too. If it was never equipped with one, I can have that issue resolved.
Thanks !
Thanks !
Is Colorado only OBDII only ?
Not really sure what this means other than the "link up." I did not notice any connection to the computer during testing. They placed the car on a dyno, connected the tailpipes to a capture hose, and drove the car under various acceleration loads.
I am guessing that with those mods even a tune will not pass sniffer test. If it were just computer scan you could after a tune. Mine has been tuned and I just went thru emissions with no sniffer. Guy said what are you burning in this thing - I can smell the fuel! I still passed since there were no codes and readiness tests were set.
St. Jude Donor '14
The factory air pump system is only there for cold start emissions. It stops running after a couple minutes. You could plumb it in to the exhaust downstream of the primary o2's and run it with a remote switch. Also have the tune set the idle to 1175rpm.
You didn't mention cats. Does your car have them?
Post the results of the emission test so we can see how far off you are.
Ask your tuner if he has a five gas analyzer.
If you can't make it with with the air pump and cats, you'll need to change the cam. Either that or look into getting a collector car registration. In most states antique and collector cars are emissions exempt.
I am definitely looking into the antique/collector car tag.
Thanks !
Do you have e85? Either add 2-3 gallons or do a full on tune. If you retune it will get you passed for sure. If you just add a few gallons it may lean it enough to pass you as well. Good luck
I live in Loveland, I failed on my Bonneville and my vette (lightly modded).. Clint at A.I.R. was able to get mine passed. He is in Arvada, If your NOX is low enough some E85 will help but probably not that much. Clint should be able to help get the tune sorted out, they have a dyno. He made me a Clean Emissions tune and a power tune so i can flop back and forth if i want. He is about 5 miles from a E-testing location, i had him tune the car and i drove over to the e-testing location and passed same day. He did suggest i ad 3 gal of E85 in with my tank of fuel, which i did.
American Intense Racing (A.I.R) -Clint
5655 Gray St, Arvada, CO 80002
(303) 422-7223
Hope this helps,
S
(303) 422-7223
Hope this helps,
S
(303) 422-7223
Hope this helps,
S
(303) 422-7223
Hope this helps,
S
Hope you get it dialed in! In GA we had several cars pass with big cams, no cats etc. that had been tuned because it was only a scanner test for codes.
Sorry but funny side note here. I got certified in GA in late 97. An inspector has to return every two years for re certification. Around late 04 early 05 I am going back for my 5th recert, At the time I have a 02 SS with LT's, A Futral F10 cam etc and no cats. Allen Futral actually came to Atlanta for a dyno tuning session and he did my car as well as a several others. Before tuning became widely available lots of people, myself included were running 02 sim's to keep the MIL off(no cats) but by the time of my recertification in late 04/05 that was passé because of LS1 edit etc.
But here is the funny part and this is the EPA at work Originally unlike on 95 and older cars, we no longer were required to do a visual inspection on catalytic converters, because the EPA said that if the convertors were bad or missing it would 100% set off the CEL on a OBD II car. but on that recertification in late 04 early 05 these guys that held the recertification classes had recently discovered that these devices called 02 simulators could "fool" the computers That was the best day ever in that class lol, the EPA only 5-6 years behind the time!!
Well, I just spent 3 hours installing a series of pipes and hoses that are 100-percent useless. But, they are required emissions system components. The air pump, as I understand it, pumps air into this system. BUT, ONLY at cold start. WTF!
Oh well, $750 later and I still have to change the cats and get a tune.
Back to the test again next week. CO sure is beautiful, but this is F'n ridiculous. Arkansas, I miss you. Coming back to ya soon.
St. Jude Donor '14
I have LG hi-flow cats. HC was 5 points high vs 1.2 being acceptable. CO was two points high with 15.0 being acceptable. I'm going to attempt to have the air pump hooked up this weekend. Tune scheduled for next Sat - earliest I could get dyno time.
Thanks !
Thanks !
Take a look at post 7. That could help you pass. Car were built for years with air being pumped into the cats to help complete the burn off. Air pumps were even used before cats became mandatory..
In Maryland, you can get an emissions waiver after spending a certain amount of money attempting to repair the problem. I think its $500. The waiver is good until the next required emissions test (2 years).
