driver's side mirror
my driver's side mirror does not always keep its memory of its position. a lot of times when i get in and insert the key, i have to re-adjust the mirror. i did notice the fault code for this shows in the error codes in the dash. any thoughts?
thanks in advance.
thanks in advance.
I agree we need to see your codes. I have seen a number of Memory issues that are corrected by a reboot of the electronics. After pulling the codes, try disconnecting the battery (neg side) for a about 5 minutes and reconnect.
ok, here they are:
60-ipc code is U1160H
AO-LDCM is B2264H
so i guess the U1160, ldcm is causing the mirror issue. will disconnecting the battery reset and solve this or do i need to check some wiring, etc?
also my driver's seat sometimes has issues. it will not go back into my set driving position after stopping for gas for example. it seems like it will always work if the car is off for a while but not short stops like getting gas.
thanks a lot.
AO-LDCM is B2264H
thanks a lot.
I would first check the connection at the door pillar on the driver side. Separate the connection and look for any apparent issues with the pins. Common problem.
Here is a link showing that connection.
https://www.corvetteforum.com/forums...-there-is.html
PS: The fact that you have a position sensor code also indicates you have an issue beyond just the door connection.
