starting issues
Old 11-10-2014, 10:47 AM
03 Mill Yellow
7th Gear
03 Mill Yellow's Avatar
Default starting issues
HELP!!!!!!!
I am having issues starting my 03 Coupe ....... I have full power @ battery ...... went out in morning .. parked for few hours and when came to going home ..... everything lights up on dash as usual .... but when turn key ..... NOTHING. ... won't attempt to turn over ......
Tried disconnecting battery .. 2 1/2 hours off ....
Tried spare key
Nothing worked. Had towed home and sat overnight .... still same problem.
Any help would be GREATLY appreciated !!!!!
Old 11-10-2014, 11:05 AM
dadaroo
dadaroo's Avatar
Does the Security indication go OFF when you put the key in the ignition?
Is this an Auto or Manual? Could be the clutch or auto neutral/park safety switch or the Theft Deterrent relay
At home I have a jumper procedure to see if it is actually starter related or not.
Could be the ignition electrical switch also. We will need to systematically do some diagnostics.
Old 11-10-2014, 11:27 AM
03 Mill Yellow
7th Gear
It is an automatic
security light does go off
Old 11-10-2014, 11:31 AM
dadaroo
dadaroo's Avatar
Try to start in Neutral versus Park to see what happens.
Old 11-10-2014, 12:50 PM
03 Mill Yellow
7th Gear
No codes thru DIC.
I do not hear a clicking from passenger floor area.
Old 11-11-2014, 09:14 AM
dadaroo
dadaroo's Avatar
Here is a way to jumper around everything and activate the starter. If it works then we can narrow down what the problem is. If you do this just put the ignition in OFF and remove the jumper once the starter works. DON' FORGET TO PUT THE CAR IN PARK SINCE YOU ARE BYPASSING EVEVRYTHING.
The jumper is just used to get the starter going. Remove it as soon as it rotates.
Go to Post 66 for the info. You can also start and run the car if you like later by putting the ignition in the ON position and jumpering like the Post says.
I know several people that have used this and it worked perfectly.
http://forums.corvetteforum.com/c5-t...ipc-out-4.html
Old 11-12-2014, 10:20 PM
ZCarr
ZCarr's Avatar
Replace the tarter and the CLEAN the disgusting corroded connections at the starter. Ask me how I know....
To starting issues
Quick Reply: starting issues
