Fuel Injector Sale @ Hinson Motorsports
Former Vendor
All of our Fuel Injectors are on sale!
Most injectors will max out at 80% duty cycle and this is the accepted industry standard. After you install heads, cam, intake, your sucking in alot more air and your motor needs more fuel! Your injectors will be unpredictable when maxed out and you do not want to be running out of fuel at 6000+ rpm. If you have any questions about which injector size or accessories you may need, feel free to ask them in this thread.
High Impedance
FAST 33lb Injectors LS2
Part# 30332-8
DeatschWerks 35lb Injectors LS1
Part# 18U-01-0035-8
FAST 36lb Injectors LS1
Part# 303608
DeatschWerks 39lb Injectors LS1
Part# 18U-01-0039-8
FAST 39lb Injectors LS3/LS7
Part# 30397-8
Bosch 42lb Injectors LS1
Part# 0280155968
DeatschWerks 42lb Injectors LS1
Part# 18U-01-0042-8
DeatschWerks 42lb Injectors LS2
Part# 13U-00-0042-8
DeatschWerks 42lb Injectors LS3/LS7
Part# 16U-00-0042-8
FAST 46lb Injectors LS2
Part# 30462-8
DeatschWerks 50lb Injectors LS1
Part# 18U-01-0050-8
DeatschWerks 50lb Injectors LS2
Part# 17U-00-0050-8
DeatschWerks 50lb Injectors LS3/LS7
Part# 16U-00-0050-8
FAST 50lb Injectors LS3/LS7
Part# 30507-8
FAST 55lb Injectors LS1
Part# 305508
FAST 57lb Injectors LS2
Part# 30572-8
DeatschWerks 60lb Injectors LS1
Part# 18U-01-0060-8
DeatschWerks 60lb Injectors LS2
Part# 17U-00-0060-8
FAST 60lb Injectors LS1
Part# 306008
Siemens 60lb Injectors LS1 - EV1
Part# 107961
Siemens 60lb Injectors LS1 - EV6
Part# 108191
DeatschWerks 65lb Injectors LS3/LS7
Part# 16U-00-0065-8
FAST 65lb Injectors LS3/LS7
Part# 30657-8
DeatschWerks 72lb Injectors LS2
Part# 17U-00-0072-8
DeatschWerks 78lb Injectors LS1
Part# 18U-01-0078-8
Siemens 80lb Injectors LS1 - EV1
Part# 110324
Siemens 80lb Injectors LS1 - EV6
Part# 109991
FAST 85lb Injectors LS3/LS7
Part# 30857-8
DeatschWerks 88lb Injectors LS1
Part# 18U-01-0088-8
DeatschWerks 90lb LS3/LS7 Injectors
Part# 16U-00-0090-8
DeatschWerks 95lb Injectors LS2
Part# 17U-00-0095-8
Low Impedance
Lucas 120lb Injectors LS1
Bosch 160lb Injectors LS1
Fuel components you may need for your build
Caspers Electronics Injector Adapter EV1 to EV6
Part# 109076
LS2/LS3/LS7 Car using an LS1 Injector
Caspers Electronics Injector Adapter EV6 to EV1
Part# 109077
LS1 Car using an LS2/LS3/LS7 Injector
FAST Injector Harness Adapters - EV1 to EV6 (8 Pack)
FAST Injector Harness Adapters - EV6 to EV1 (8 Pack)
FAST Fuel Injector Spacer Kit
Makes an LS3/LS7 Injector have the same height as an LS2 Injector
Katech Fuel Rail Spacer LS2
LS1 Injector in an LS2 Manifold and Fuel Rail
High Impedance
Part# 30332-8
Part# 18U-01-0035-8
Part# 303608
Part# 18U-01-0039-8
Part# 30397-8
Part# 0280155968
Part# 18U-01-0042-8
Part# 13U-00-0042-8
Part# 16U-00-0042-8
Part# 30462-8
Part# 18U-01-0050-8
Part# 17U-00-0050-8
Part# 16U-00-0050-8
Part# 30507-8
Part# 305508
Part# 30572-8
Part# 18U-01-0060-8
Part# 17U-00-0060-8
Part# 306008
Part# 107961
Part# 108191
Part# 16U-00-0065-8
Part# 30657-8
Part# 17U-00-0072-8
Part# 18U-01-0078-8
Part# 110324
Part# 109991
Part# 30857-8
Part# 18U-01-0088-8
Part# 16U-00-0090-8
Part# 17U-00-0095-8
Low Impedance
Part# 109076
Part# 109077
Former Vendor
