Rotors upgrade for C5
I am thinking about replacing my rotors and painting my calipers this winter..good winter project. I have seen complete kits, rotors and rebuilt calipers that are powder coated. I am interested in slotted/drilled rotors for looks. Pictures of what you did would be nice. And it would be a good time to replace the brake pads. Price is not an issue, but I don't want to over pay just for a brand name either. So, what do you say..paint the calipers or get them already painted?
Did mine 2 years back with Dupli=color Caliper Paint and they still look great . the key is getting the caliper as cleen as possible . use a file to highlight corvette on the front....xzo
I put a little Vaseline on the surface of the letters and just scraped the paint off with a razor knife after it was dry. It came right off and looked perfect.
Funny, I would prefer a brand name when buying brake products. Although I know the production technology is well understood throughout the industry.
Most brand names are such because they market a good product . Others may have a comparable product, but it was not achieved easily. And given that the tech is well understood, where are the cost savings from? I hope not materials, build quality or labor, my personal last choices for areas of economy in brake manufacturing .
I guess I am concerned about going cheap with a very important system. I would be bummed if I couldn't easy reach my eBay seller with a few complaints about Chinese product quality using only a bedside hospital phone.
I used G2 caliper paint. Take your time and mask off areas and it's worth the effort. My calipers came out perfect !!! G2 is quality stuff. Give it 2 or 3 coats. It's like an expoxy paint mix. Un-used paint turned into a rock in the can about 10 hours after mixing.
That's what I have purchased. How many kits did you use?
Just one kit will be enough. Make sure u clean your calipers with soap and water , then with the brake cleaner and let them dry. One kit was enough to give each caliper 3 thin coats. If you take your time and do it right you wont be disappointed. My calipers look perfect , they look powder coated. To get the raised CORVETTE lettering clean just use a razor blade and scrape off carefully.
Rotors
I have a set of drilled & slotted rotors that I'm taking off my car that will be for sale if you are interested. PM if you are. You PM is full as I tried to send you one earlier.
Tim
Tim
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
God,,, I LOVE the slotted and DRILLED look! Truth be told,, the drilled rotors look great BUT,,,,,,, can CRACK if used aggressively.
I had an 06 Z-51 Coupe. It came with OEM Drilled Rotors.
I can tell you for a FACT that the drilled holes will CLOG with brake dust in short order.
Sure,, its pretty easy to clean them but, they clog and do that in short order. Drilled rotors,, If used aggressively can and will crack between the drill holes.
SLOTTED ROTORS: Slotted rotors don't clog. They don't crack.
In my honest opinion,,, If you want a fail proof brake rotor, find a quality SLOTTED rotor.
BC
BC
Supporting Vendor
St. Jude Donor '11,'13
For a quality brake pad take a look at the Carbotech 1521.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F: $148 R: $128 Less 5%.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Been running Baer rotors on my '98 many years ago now. I put them on after having new rotors on the front a couple of times under warranty. Probably got 45k on them now, no issues at all - and they were used (but not many miles) when I bought them!
I run Hawk HPS pads with them. They look good and the car stops extremely well. What more can you ask?
BrakeMotive
I originally had the Baer Eradospeeds - pretty expensive - supposed to have a life time warrantee - they warped - too bad - no replacement rotors in the cards.
Shopped around and found the Brake Motive rotors $180 with brake pads included. Why not give them a try - 2 years later they look like new and are still perfectly true. I never used the pads as I use ceramic pads - but I believe you are wasting your money for anything else.
Mine are powder coated to match the car, as are the brackets (and the C6 Z06 sway bars). The rotors are Wilwood two piece, which pulls some weight out as well.
If you are not interested in a 2 piece rotor, I recently bought some of the NAPA rotors for another car. They are now fully coated with a silver material that looks pretty good. Once you brake on them a few times this wears off of the braking surface and the rest of the rotor remains silver. Its a pretty slick setup.
