Camber
Camber
Hey guys, I just swapped to a c6 rear cradle. Now it looks like I have some neg camber. Does anyone know if I have to swap the uppers too? it looks kinda bad. Not sure if its just looks tho
Why don't you just do an adjustment yourself and see. If you are not comfortable with doing the final alignment you can take it to the shop after you at least confirm you can correct the situation. Rear camber adjustments are pretty easy, rear toe is more difficult since you need to match the centerline.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree.
Turn the adjustment bolt. Make the camber ZERO for a rough adjustment and take it to the shop for fine tuning and toe adjustment.
Don't forget to roll the car back and forward a few feet to allow the tires to settle to the new adjustment between each cam movement.
