Fixed my HUD!!
Fixed my HUD!!
Today, after an exciting oil change and spark plug change, I decided to tackle the dreaded "fallen HUD" fix.
I read the threads about removing the dash and then KCJeff's thread for how he fixed his HUD, (THANK YOU KCJeff!!!) and dove in head first. I was able to get it working again but the first time I installed it, but it was still too low and wouldn't adjust higher. I pulled it out and removed the mirror again, then reinstalled it, ran the adjustment all the way down the pulled it again, re-installed the mirror, and reinstalled the HUD unit. VOILA!! It now showed up on the windshield and I could adjust it up and down as needed. I also cleaned everything while I had it open. Thanks to this forum and some very awesome folks, this HUD is back in view again!
You guys DEFINITELY make this forum the best one going for any Corvette owner!.
ps - sorry about the crappy pic but I used my iPhone.
Had the same problem and also used the guide here to fix it. I too had an issue with the mirror not moving after reinstalling it. Like you I tested it before putting everything back together, so I simply removed the projector and did what you did. Then I thought just how much time and aggravation I saved by testing it before reinstalling everything else.
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Thanks and good luck to you too!!
Nice to read positive stuff, and this job is on my to do list.
Since both had posters here had the same problem in common is this an adjustment or something that is missing from the instructions, or is this just a coincidence?
Call me paranoid , but if you were working with my level of skill, you would try to make it as surprise free as possible also.
Hey guys, My "HUD PROBLEM" isn't about adjustment, in the 'location' sense of the word.
Mine appears to be that it doesn't go "BRIGHT" in sunlight...
Any ideas?
Any ideas?
