Lightweight battery
Lightweight battery
So I've read several threads about installing the little motorcycle batteries and people seem to have great results. My car is almost exclusively a dragster, so no, it wont be a daily concern. I plan to run a trickle charger because I read one guy got 5 years out of his Braille that way.
Here's a few links for those interested:
http://www.z06vette.com/forums/f5/br...all-pic-88158/
https://www.corvetteforum.com/forums...y-install.html
https://www.corvetteforum.com/forums...tall-pics.html
Surprisingly people have been using these for both racing and daily driving with no problems. The car consistently starts for years. Interesting..
Here's the one I am most interested in and have a question about. Its only 1.3 lbs , how can I tell if this will work or not? Im already surprised that the 220ish cca one's do the job. This one says only 124ca on the side.. but it's advertised as a racing battery just like the others.. and the price is good too for that kind of weight savings.
http://www.summitracing.com/parts/brl-g4l/overview/
Right now I have a 44lb Optima yellow top in. Way too much. Can you imagine a 42.7lb drop! These guys are excited about loosing 20!
Others I'm interested in seem to be the more common AGM type. As you can see in the threads, people are having good results with anything from 170cca up to 350+. (Still dont understand how this is sufficient, but apparently it works).
Looking for anyone's experience or suggestions. The little lithium ion one Im interested in would be great, but is it too new that no one has tried it out?
I have been using the 17 lb braille battery without too much problems. I don't see that a 1 1/2 pound battery is going to start the car, besides, none of the threads are talking about such a small battery, are you sure that is the one they are talking about.
my experience is with two cars, currently running the 17 lb braille in both. I do have a slight battery drain on one car, I think it's the ipod but I try to put the battery on the ctec if i'm not going to be driving it for a few days, it will drain in a few days otherwise. If they drain, they can be brought back "slowly" , I've also had a few gone bad where the side bulged out (3).
The other car, (383 Ci) has one in there and it starts right up every time (no batt drain)
I've been running them for about 5 years now but have gone through some batteries ...
IF I can get three years out of one - I'd be happy
St. Jude Donor '14
If you didn't already, measure you cranking amps cold and hot. Pay close attention to the initial hit. Most are about 150 cranking but the draw is almost double. Here is my suggestion. It's still 30lbs lighter.
http://www.summitracing.com/parts/brl-b14115/overview/
If you didn't already, measure you cranking amps cold and hot. Pay close attention to the initial hit. Most are about 150 cranking but the draw is almost double. Here is my suggestion. It's still 30lbs lighter. http://www.summitracing.com/parts/brl-b14115/overview/
I have been using the 17 lb braille battery without too much problems. I don't see that a 1 1/2 pound battery is going to start the car, besides, none of the threads are talking about such a small battery, are you sure that is the one they are talking about. my experience is with two cars, currently running the 17 lb braille in both. I do have a slight battery drain on one car, I think it's the ipod but I try to put the battery on the ctec if i'm not going to be driving it for a few days, it will drain in a few days otherwise. If they drain, they can be brought back "slowly" , I've also had a few gone bad where the side bulged out (3). The other car, (383 Ci) has one in there and it starts right up every time (no batt drain) I've been running them for about 5 years now but have gone through some batteries ... IF I can get three years out of one - I'd be happy
Subscribed
St. Jude Donor '14
Thought it was pretty cool that the bat came with this spec card. 636 Amps! That's great for this little thing!
Attachment 47846929
Attachment 47846929
Harbor freight has a float charger for $6 bucks. Read a lot of good reviews. I think I'll try it out. Should give peace of mind that the car will at least start when I need it too for the life of the battery. Not sure if that will have an effect on the life of it. But I don't expect it to last longer than 2 years anyway. It will be interesting to find out.
I'm on year two with my 15 pound Braille. Daily driver. Never had an issue. It never does get really cold here but it does get a little warm. Never a problem.
edit - should say into year two, haven't completed year two....
Unfortunately the float chargers at harbor freight say "for led acid batteries only". I just came from there. Opted not to put one on mine since it's an AGM gel type bat. Gonna do some research and find one that will work for a good price.
Just installed mine today:
Nice work. When the battery is this small I'm sure upright or lying down doesn't really make a difference. I just read that laying it down makes for a lower center of gravity. So I wanted to instal it that way. I haven't had a chance to use the car much, looking to seeing if there's any difference in the way it feels driving, fuel economy, ET on the drag strip, etc.
The C-TEC chargers are popular on the forum. I have one, and it works very well. They cost around $65.
Thanks bro. I had a 25% coupon from Summit on purchase off 200.00 so I went with the mounting kit with the battery as the battery alone was not enough and it expired the end of this month. So thanks to your thread for the perfect reason to use it
I installed it this afternoon and drove it 3 miles home. I will mention this. My spec sheet showed it tested and boxed on 8-06-2014 and it fired right off after sitting 4 months. I have started looking for places close to Destin just to find a place to weigh it. My curiosity is killing me lol
