Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
#41
thanks gene thats exactly what i would like to do. can you sell me the package ? i see you are in Reading PA. i am quite near in Villanova PA. Do you have these in stock and can i pick it up anytime soon> Please use my email for details: rauscher@wistar.org, or respond here.
Thanks Frank
Thanks Frank
#42
Premium Supporting Vendor
Thanks Frank
Thanks Frank
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
#43
just emailed you gene
I'm not on the forum every day so it is best to email or give us a call. If you contact me I will be able to arrange pick-up for you, no problem. My email is gene@cultragperformance.com.
#44
I know this is a suspension forum. But I noticed you guys sell clutches also. I have a modded 2000 C5 FRC ... still riding factory clutch for 133k miles. I would like to upgrades to ZO6 or Zr1 Clutch kit? being I do autocross and road race at times. I am not sure what part number will work? Can you provide any info on that?
And I will be ordering the shocks and sway bars soon also.
#45
https://www.corvetteforum.com/forums...rformance.html
#46
I was planning on doing the C6 Z06 shock upgrade because I have never replaced my shocks in the 11 years I have owned the Corvette. I thought replacing the end links while I was at it made sense as long as I am replacing the shocks. Considering your price is $120 for the four end links and $110 if I add them to the sway bar package it is like getting the sway bars for $247 and not $257 (small difference I know.)
Will the sway bars transform my performance or do I get most of the improvement from the shocks?
I drive on Los Angeles' crappy roads with lots of potholes and damage so I am concerned I won't get a ton of benefit from them.
#47
You could always try to order either the shocks or the sway bars first to see if you just like adding one of them first.
#48
The shocks will improve the ride. Even with the car being 11 years old, if you replace the shocks with even standard replacement shocks so you would definitely notice a difference with the Z06 shocks. The sway bars are for cornering. That's why we recommend them as a package. The Z06 shocks are a tad stiffer, so you'll feel more bumps in the road, but it also won't be living driving on a washboard either.
I need to spend next weekend fixing the power steering and my driver seat.
This repair will need to wait for another time. Let me know if you run a sale and I will scoop up the shocks, sway bars and end links. I need to do it. I just don't need to do it now.
Thank you.
#49
The car is 20 years old. I have had it 11 years.
Thank you.
Thank you.
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#51
I know this is a thread for your suspension package, which by the way is fantastic.
The 'complete package' that I bought from you has taken my 99 coupe from Bangor Me, to Key West FL, and now enjoys the back roads of western NC.
My question to you is....
Do you sell driveshaft couplers?
I bought an 01 torque tube assy with shaft, but it still needs couplers.
I will NOT do the cheap ones. "Chevrolet Only".
#52
#56
You'll want to do the LS7 clutch kit which is perfect for what you're doing. You can see the link below.
#57
To answer your question the C5 Z06 clutch kit is $573.33.
The C6 Z06 clutch kit has 20% more clamping force and 1" more of surface area and is less expensive. Follow my advice.
#60
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Had to reply to this post. TTT!! I ordered a LOT of stuff from Gene and Patrick over the past years. I've always received excellent service and prompt delivery.
Gene and Patrick know their products and are ALWAYS the GM Product go to guys.
If you have GM Parts needs or questions, GIVE THEM A CALL!!
Bill Curlee
Bill Curlee
