New alternator Charge system fault message 99 A4
Got a 99 a4 and had to replace alternator due to bad bearing, shop said it was an oddball bearing and couldn't be rebuilt, got a lifetime warranty unit that it apost to be the replacement for it but now I got charge system fault everytime I start my car, my questions are:
Is there any aftermarket units that will work on a 99 a4 or does it have to be the original valeo 110 amp made in France?
Step one should be to get your old unit back unless you were wise enough to keep it. NEVER heard of the Valeo bearing being oddball. I assume they just didn't have it. Looks like they are on the hook to get you an alternator that works since you have a lifetime warranty.
I don't know if anyone else makes an alternator that properly interfaces with the C5 PCM.
Here is one site that promises their rebuilds are from Valeos and that they are C5 compatible. Not cheap but you can look around for others.
http://nationsautoelectric.com/highamp-corvette.html
Nope didn't keep it had no idea that it was special and I needed to, dumb move on my part and he said the new one that the core is renuilt from a valeo but in Mexico not like the original one which is made in France, so I'm Probally screwed? Or does anybody know a part number or anything for one that will work for the 99 corvette without the charge system fault?
Received 3,812 Likes
St. Jude Donor '03-'04
How can an alternator as advertised by the link above that offers an upgraded alternator of 150 amps, work on a closed loop pcm that only expects to see 110 amps at full duty cycle.. This is my first and last post in this thread.
I got a 99 C5 and replaced my GM alternator with one from NAPA that was direct interchange. Never one issue on street. Make sure it has same output as original GM when you buy.
