how to reset oil remaining guage
I tried to reset theoil life remaining guage by pushing the reset button , no luck. Is there a trick on doing it, like holding your breath while pushing the reset. Any help..............Thanks
Received 1,261 Likes
key on engine off
I just did that - no problem. IIRC you have to hold the reset button for a few seconds, not just give it a quick tap. You should hear the beep when it resets.
does that actually work??... mine will not reset with the car running, it has to be off with the key on... hold the reset button on the dic with the oil life monitor on the screen and it works fine... I know the gas pedal trick works on a lot of other older gm cars/trucks but didn't know it did on ours
Thats funny, I also found out the hard way.......I had turned up the stereo with Joe Bonamassa playing real LOUD. I think it was ''I just got paid''.
(see it on you tube with other songs) and it reset...
