C5 right hand air check valve mod
Came up with this mod. I based it on a mod I saw on YouTube. I removed the r.h. tube. Cut it at the second elbow. Bent the pipe out a bit. Braised a fitting on the end and screwed on the valve. I ran 5/8 hose behind the motor to the original T pipe from the air pump.
Hope this helps someone.
I tried to clean it as per Bill C. directions, but it did not work.
I guess the answer is no if it took you less than 1 hour, but just to confirm, did you have to remove the intake in the first place to do that mod. I had to replace it once for code P1416 and had to remove the intake. After many many miles, code came back and I have to do it again. Removing the intake is not my favourite sport after also doing it for oil pressure sensor.
I did not have to pull the intake. I came up with this procedure with help from a YouTube Vid then changed it to my taste.
I left the original valve and the remainder of the cut pipe attached to the back of the motor. I made this mod in favor of pulling the intake and to make the valve easy to access.
Thanks, something to add to my C5 to do list.
When changing the exhaust manifold or header, instead of bending the air tube to get it out of the way the new short tube can be disconnected from the check valve. Good idea.
My take? Delete all that crap which cleans up the engine bay a LOT and if you have to face emissions test like I did in Atlanta pay a tuner 50-100 bucks to turn those codes off Sorry that AIR crap looks like **** under the hood
OP,
Can you post more pics of the hose routing, and where you T'd into the fitting on the other (driver) side?
thanks,
Don
thanks,
Don
I would never do that to my, or a customers car. It's only 1.8 hrs flat rate to R & R the intake manifold. Then you can perform the GM TSB to add a silicone dam around the knock sensor wells to prevent water rusting & shorting out the knock sensors.
Russ Kemp
Russ Kemp
And once you pull the intake once and see how RIDICULOUSLY EASY it is, you would never consider a hack like this. Shouldn't take more than 30 minutes to pull the intake after you've done it once.
But reading all the replies, I'm kind of changing my mind and I have not decided if I will do the mod or remove the intake....
I did basically the same with mine.. I added one on the passenger side when i did my LS7 Exhaust Manfiolds. I Have the original still in place, but i did get a brass fitting and silicone hose to "Delete" the one behind the manifold if i ever remove the intake i will do the delete then.
I have corrected the angle on the pipe so its straight now and had to make custom fittings for the LS7 manifolds. But i did the install on the car, Cut the pipe on the car and put it all on without removing anything.
