abs delete on a 02
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
My ABS is removed.
Just two lines from the master cylinder to two tees and lines to each wheel. No fancy valve to bias the fronts vs the rears.
mykream (11-29-2022)
I called sjm and they explained everything to me and I got the parts I need. I will be pulling everything tomorrow. Capthuff why would you not want a proportioning valve? Your fronts always do more braking than the rear.
AMP Racing
And 4DRush is correct.
Out of the master cylinder:
Front into a tee for the two front brakes
Rear into a tee for the two rear brakes.
Bump did anyone figure out how to do this? So there no rewiring just t the lines into each other and your good to go? T front to front then back to back? Do you need to unhook the speed sensor on your wheels? Mines a 02z
AMP Racing
The EBCM uses the wheel sensors to assist with TC/AH. However, you do not have to remove the wheel sensors if you remove the ECBM.
