Spark plugs/wires/battery died - Would this cause ABS/TC lights to turn on?
So, I just did the following on my car:
1.) New plugs/wires
2.) Replaced the hazard switch
3.) Battery died when I left the hood open overnight
And after all of this, my ABS and traction control lights are lit. Would the battery dying possibly cause this? Or is this coincidental? It happened right after I got finished with all the work.
1.) New plugs/wires
1.) New plugs/wires
1.) New plugs/wires
I cleared all of my codes and I still have the problem. I drive for about 60 seconds and both the ABS and Traction control error lights turn on. Any idea what I should be looking at? It doesnt look like I have any relevant error codes.
RFA C2115 - Tire sensor
BCM B2721 - PASS-Key Detection Circuit
PCM P1631 - Ignition switch
HVAC B0446
SCM No comm. - Seat control module
HVAC B0446
HVAC B0446
HVAC B0446
HVAC B0446
HVAC B0446
I used the DIC and Im pretty positive those are the only codes shown.. Ill have another look to make sure.
Clean the contacts on the inside of the ignition switch would be my fIrst inpulse. It can cause all these issues.
https://www.corvetteforum.com/forums...ch-repair.html
Try this easy free fix and report back.
Are you sure the battery is now fully charged? You don't have the typical codes associated with a low battery but be sure. That theft deterrent thing could leave you stranded. Does the security light stay on?
Check them again. For instance, If you have a current P1631 (part of the theft deterrent system) the car will just start and stall (per service manual for a 99). It would be very unusual for the abs service lights to be on and no codes. Do not discount history or no comm codes as they also tell a story.
The battery should be fully charged unless Im having a problem with my alternator or battery.. Ive driven it about 100 miles since the battery last died, and the battery is fairly new - about a year old.
The security light comes on sometimes but the car doesnt ever start and stall. Every once in a while the engine wont turn over (instrument cluster fires up but the engine does nothing), but after waiting about 5 minutes it starts fine and drives normally for a few months until the same thing happens again. Its mostly a nuisance.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you turn the IGNITION SWITCH (OFF) and read the codes, the ones for the EBTCM will CLEAR and usually not show up.
Try this:
Clear ALL the DTC. Take the car for a drive. When you get the DIC Messages for the EBTCM, (WITHOUT TURNING OFF THE IGNITION), press reset until all the messages are gone and then read the DTCs.
IF, you have EBTCM messages, YOU HAVE EBTCM DTCs.
Post what you get using that procedure.
Bill
Try this:
Bill
