LS1, LS2, LS6 oil pans
Hi All -
One more question for you this morning, in regards to differences in oil pans over the years.
I have a 97 C5, which has an LS2 in it. From what I can tell, the LS2 was installed using the original LS1 oil pan.
I know that the LS2 has a different pan from the LS1 and LS6, since it doesn't have the larger ("batwing"?) extensions on the side.
My question is, do the LS1 and LS6's, 97-04 all have the same pan, or does the LS6 have an improved design over the LS1?
The basis of my question is that many of the C5Z T1 guys have run wet-sumped with their LS6 for years, whereas the LS2 proved to be immediately fragile because of the poor oil pan design. So, interested to find out of my LS2 is in better shape because of the (better) LS1/LS6 pan, or not.
Thanks all,
-Jake
Thanks all,
-Jake
Hi mate
As far as my c5 parts manual is concerned they all seem to be the same part number 12561828 .
This seems to be an easier way , what an excellent site this is , well done Gene
http://www.cultragfactoryparts.com/o...h_str=12561828
Hope this helps bud
Hope this helps bud
