ABS/TCS/Service Soon - Observations
Here is a link on separating the cylinder from the switch.
https://www.corvetteforum.com/forums...-cylinder.html
Do you need guidance on accessing it?
Got the new ignition switch arriving in a day or so. Also sent out the EBCM to be tested and repaired.
I may have an independent shop to the install of both and test if problem not corrected. Will let folks know what happens. Thanks again everybody. (I recognize this may not ID if the switch was the culprit causing the EBCM issue but see this all as preventative maintenance. I also recognize that the EBCM may not be broken but the fix with shipping is $71 - worth the try to me.)
If you're interested in furthering the emphasis on acquisition of critical replacement parts, then cast a vote for GM response to the same question.
Click on the link and cast a vote for C5 parts, to make this the topic of the week;
https://www.corvetteforum.com/forums...an-2015-a.html
Hi sorry for the slow update. Parts are in - got a new ignition switch and the Ebcm is back from MAS. Repair is guaranteed :-) we shall see!
My question is - shall I install the EBCM first and see if that is the fix? Or, should I do the ignition switch to cure the low volts and then install the EBCM?
I want to install the EBCM first to see if that was it, then the ignition as preventative maintenance. But want to confirm that low volts will not hurt the "repaired" EBCM. Plan is to do the job this Saturday.
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
Gotcha fellas - ignition switch first! I will be sure to post up the results. When I put the switch in I will first check all the volts to see a anticipated improvement. Then the EBCM.
Cheers
Cheers
I had the same codes and tcs no comm. checked all the grounds and connectors. Ended up having to get a new ebcm which fixed the problem.
Did you get a new ebcm or did you have yours repaired and sent back to you? If the latter you will have the same problem. There is no repair for the no comm code just the c1214 tcs code. Hope everything works out for you.
So the thread has been dormant as the snow. A forum member turned me onto a source of brand new ebcm units on Amazon
The price went down to $550 and there are two left so I bought one and will try that! Also requested a refund from the repair company on my old ebcm - any bets I get my $59 back??
I figure I can spend that much in diagnosis so let's shake the dice and see if this will do the trick! Looks like I can return it.
Will update when I put the new one in.
#35
The happy ending! The Ebcm was the problem. Installed the new unit and all is well, competitive mode works and no codes! Took me 90 minutes to do the swap and then needed to clear the codes. When I first installed the abs light cleared but. Traction did not. I then cleared codes on the DIC and now it is good to go.
I did not change the ignition switch. While voltage did seem to test low, I had no symptoms besides the ebcm being bad. I did buy a new ignition switch for when the time comes.
What I conclude is that when a Z06 has a battery replaced and especially when a very dead battery is charged in the car, these events seems to lead up to an EBCM failure. Charging a very dead battery can potentially damage sensitive electronics is my supposition.
It was very cool to have the help of deselordre and 8vette7. D - I bought my unit from the same vendor on Amazon you recommended - thanks! This diy job saved me a $1000 I bet!!!
Corvettes rock
Corvettes rock
#37
With regard to your comment on battery charging here is what I tell people.
If you charge a dead battery in the car DISCONNECT the negative cable first. Normal car chargers produce DC square waves that can pound the electronics and damage them. A really dead battery cannot filter these. If a battery is just a little low there is no concern
A car charger may not be as sophisticated as the ones in a computer based on the design for replicating a true DC voltage.
#38
#39
Abs, traction, service engine soon
I have an 01 Coupe that had a dead battery. Charged battery and reinstalled. Service Engine soon, ABS,and traction lights came on. Also had a P1251 code. Test battery and it didn't have good load (12.3-5) bought new battery but code and warning lights still present. DIC won't let me reset codes, keeps returning. No problems prior to battery dying. Any suggestions?
#40
Are you certain the battery (new or otherwise) is fully charged?? A good battery at full charge will measure 12.7 to 12.9 volts when measured across the battery posts using a digital multi-meter with the neg battery cable disconnected.
Are you certain that ALL battery connections, including the one at the starter solenoid are clean and properly tightened?
When you say you cannot clear the codes, did you pull the codes and attempt to clear them while in the pull code procedure?
If you don't know how to pull codes here is how:
OR
http://www.c5forum.com/ayc/dtcdic.php
The video shows how to clear codes from within the code pulling procedure.
How about some info about the car??? Year, modifications? Headers???
OR
