Time for new clutch, recommendations ?
I just went from a monster stage 3 to a monster stage 2. I'm at 457rwhp holds great much more street friendly than the 3. Unfortunately I have no comparision to stock though. Others I would look at is the ls7 if your going to stay around 400-450 area or the mantic er2 has great reviews. Plenty of reviews on here if you search a little bit.
Former Vendor
Monster stage 2
Monster stage 2 with the lightweight billet steel flywheel. This set up is lighter than a ls7 kit. Price is reasonable and Good for 500rwhp.
Clutch has a great feel and only slightly stiffer pedal pressure than my original ls6 clutch. Deals for this setup show up on the forum a lot.
I went with the McLeod rst, red street twin. easy to modulate, and rebuildable, I bought on price and reputation with the goal in mind of a lighter clutch pedal stroke, as the old knees have some miles on them . It is billed as holding 800 hp, so should last for a while in my stock installation. I have been running it for a couple of years, no complaints, other than a dull slight rattle noise from the extra disk once in a while at idle. If It bothers me, I will cycle the clutch pedal and it goes away. I might do that at a long light, but it is not intrusive, and only happens when the stuff comes to rest a certain way.
I would assume that the technology is well understood throughout the industry, given a decent amount of money I would expect fine results, provided the product matches your purchase goals. Since the factory item is for sale, I would expect most other products are aimed at different needs. Be aware that some are designed for speed, not pleasure driving, since the factory clutch is still in the market.
Received 1,261 Likes
well we need to know what kind of power you are making or plan on making in the future... we could recommend an ls7 clutch not knowing you're making 850 to the tires and you would be pissed off when it slips like crazy... plenty of people are willing to help but when you ask such a vague question and then get an attitude what do you expect?
Former Vendor
Let's start over.
What is done to your car?
How much power does it make?
How do you drive it?
How do you use it?
What's your budget?
Give us this information and we'll recommend you a clutch. Of course I'll recommend Monster because I own it, but, there are other options that people here will recommend.
Start by giving us enough information to help you, then we'll help you.
How do you use it?
What's your budget?
So much information to assist us with your decision.
I have the Mcleod RST twin disk on my 640WHP supercharged ZO6, mated to their lightweight aluminum flywheel, and Tick Master cylinder, and I love the feel. A little more firm than stock, but not bad. And with the lightweight aluminum flywheel, it's so rev happy - feels like a race car. Took a while to get used to, but once used to it, it's like second nature. I daily drive mine as well.
By the way, I have heard nothing but good things about the Monster clutches as well.
Let's start over.
What is done to your car? - Vararam, cam, LS2 intake, headers w/high-flow cats.
How much power does it make? - 400'ish
How do you drive it? - Daily driver
How do you use it? - Daily driver
What's your budget? - depends what's required with the info provided above.
an ls7 probably would be the cheapest and would be fine at your power level and give you a little room to grow... I would stay away from a stock ls1/ls6 replacement as they are known to cause shifting issues at higher rpms, surely you have experienced this before if you drive the car hard... if you don't want to spend a grand then you can pretty much count out a twin disc... a good aftermarket single disc would probably run in the $600-$700 range... also depends how much power you want to add in the future, if you plan on boosting it then I would go ahead and get a good twin disc now, a clutch is not a job I would want to do twice if it can be avoided
And yes, I have noticed shifting issues when jumping on it hard. I've been looking at a Stage 1 SPEC clutch set-up. And I did find a local speed shop to do the clutch swap for a fair price.
