billet due rails do I need a regulator
billet fuel rails do I need a regulator
I am in the process of rerouting a lot of things under the hood of my vette to make it more aesthetically pleasing. I want to do billet fuel rails, and would like to know if I need to add a fuel pressure regulator to the new system? Its a 2001, returnless system, and it is my understanding that after 1999, the return circuit ended at the fuel filter. The car is not going to see serious power upgrades, headers and a tune is about it. What do some of your retunless systems look like, and/or require?
HTH
At what point would it be necessary and/or a good idea to add one? Is it horsepower dependent, or certain mods dictate when one should be added, like fuel pumps, different injectors or whatever?
The numbers vary a little from what I've seen, but generally speaking, the 600 to 650 (~) fwhp range is where all this starts becoming necessary. I'm in the 635-640 range with a pump upgrade and larger 50 lb injectors and the OE filter/regulator works fine with my OE fuel lines.
HTH
https://www.corvetteforum.com/forums...-location.html
"Specifically, 97-98 on the rail, 99-early 2003 on the frame rail, 2003-2004 in the tank." Info supplied by Lucky131969.
I was just trying to keep things as short-and-sweet as I could for the OP, and not get into an in-depth response regarding the entire history of the C5 fuel system and all it's design iterations. I have to work on my brevity sometimes.
Received 1,261 Likes
Big HP is the main determining factor, as the stock fuel system starts to become inadequate in supplying enough fuel volume. Fuel VOLUME is the key. This would also dictate more than just a regulator as new (larger) fuel lines, bigger injectors, higher capacity (or dual) fuel pump(s) then become necessary as well. Blower and turbo cars are common candidates for a new fuel system design, less so on NA cars, but even they eventually have limits as well.
HTH
HTH
