Diagnostic code 2723 Question
I've got the 2723 code, which I cannot get to clear.. It has something to do with the Theft Deterent System... Bacically the car will not start.. I've cleaned the ignition key as well as the sprayed electronic cleaner into the ignition key switch, trying to clean the contacts on the inside.. I've got the CLB bypass too.. Not sure where to start from here
Fairly common problem- there's a little switch inside the lock cylinder that reads the resistor on your key. The switch has fine filaments that are easily damaged (voice of experience). Switch replacement cost me about $500.
See the thread below for more info. Good luck.
https://www.corvetteforum.com/forums...-resistor.html
Sounds like a lock cylinder issue..Pretty cheap got mine off Amazon for 45 shipped had new tumblers replaced for 30 bucks and also cleaned my ignition switch free. Check the how to..Here some stuff to get you started or google "2723 code wont start" lots of stuff but easy and cheap fix dont take it to a dealer unless you like getting bent over
https://www.corvetteforum.com/forums...cm-2723-a.html
https://www.corvetteforum.com/forums...-no-start.html
https://www.corvetteforum.com/forums...art-b2723.html
