LS7 clutch or MCLOED
I do not it is best to call mcleod directly on that.
Can I reuse my mcleod steel flywheel with 20k and just have it resurfaced/smooth or do I need to buy a new one? I just bought a rxt to replace my rst but was going to reuse the mcloud steel one. Are they just a 1x use? Again this is not a stock flywheel but a mcloud steel flywheel..Never jeard of them as a 1x use as long as its in tolernace to be resurfaced..
My 98 with mods was pushing 506 rwhp/484 ft/lbs torque and running McLeod RXT, which I found to be very acceptable on the street. The engine is being rebuilt and will put out in the 800 hp range so a little over 700 rwhp with a lot more torgue, details unimportant. I had ~6000 miles of street driving on the clutch when the engine was pulled and the clutch showed excessive wear. The McLeod flywheel was easily resurfaced but the plates went back to be rebuilt. Now I have a problem. The car has to be tuned on a chassis tuner but McLeod strenuously warns against breaking in a new clutch under these conditions. Anyone got a comment besides me just being SOL.
The car does not have to be entirely tuned in a chassis dyno, in fact it really cannot. If you are going to drive it on the street it needs to be tuned on the street first for drivability, cruising, etc etc. That is where the clutch would be broken in THEN you can strap it to the dyno and tune the wide open and anything else. That is the standard normal progression of most any tuner and shop.
No problem.
I apologize if your clutch was offended by his post.
It's like new brake pads and rotors. Do you really want to ride hard on them so you can glaze the pads? Prob not.
Do like coSPEED2 says. He's right.
I agree here. I do not like people installing clutches and then beating the bookoo out of it on the dyno. You can if you're 100% positive the clutch is installed perfectly but who knows. That is why they want you to break it in with daily driving so you can feel changes in the clutch if something is going wrong instead of hitting 6500 RPM and then boom cause something went wrong on the install.
I am just under 450 rwhp and daily drive my vette in the summer with a trip to the local drag strip 1-2 times a season. My LS7 clutch works well for what I use it for. However, I just street run mine for the most part. I just could not justify spending the cash on a big dollar clutch for how I use the car.
