LS7 clutch or MCLOED
I have a 2003 z06 intake, headers, tune making just under 400whp. I need a clutch because im tired of having the pedal sticking issue. What clutch do you guys recommend. I dont wanna have clutch issues again and wanna do things right the first time around because im not made of money. I do visit homestead motor-speedway once a month for drag racing. Also if MCLOED clutch is purchased do i go with the rst or rxt and which one has a longer clutch life. Thanks
Monster stage 2
I have the same mods and hp. Installed a Monster Stage 2 with lightweight billet flywheel. No more. clutch pedal On the floor and clutch feel is great.
Former Vendor
Thanks for the recommendation.
What are your future mods? If you don't plan to break the 600ish hp mark a ls7 is a good and budget friendly clutch. If you plan to go for more power go with a Mcleod. The RST is an organic surface material clutch I believe. Organic clutches burn up easier when slipping I believe. The RXT is a metallic material and is better for launching but will make more noise due to the materials. I personally have a RST and make 735 rwtrq. Its been great. I do not really do much track or dig racing though
Not to hijack your thread with negativity, but you mentioned the clutch pedal sticking? Have you checked/changed your clutch fluid recently? That could certainly be a culprit... Just something to think about before dropping the $$$ on a clutch.
RST gets our vote along with brand new GM hydraulics! We also have THE BEST prices on the monster as well. the RST will be very easy to drive, its organic so it can slip a little if you are that type of driver and itll hold like crazy. Smooth engagement also.
junk clutches. kick that junk **** along with their dual friction bs to the curb with the other ho's and back hand it a couple times across the face before you kick it.
people need to stop comparing the ls7 clutch to anything. if you want an ls7, make sure you are running a car with mild bolt ons. it's a stock clutch. it's nothing special. i'd run it in a car that sees no drag racing, only street racing that's pushing 450 hp. if you want to run that clutch and do a summer's bracket racing, no more than 400 hp. it's not that great of a clutch.
other options and proven are the mcleod rst and rxt. the rst uses a stock type disc and holds around 800 hp. you can spray it the clutch will slip because of the disc material as it is really setup for crazy n/a power. but if you want to spray, go with the rxt which uses a stronger metallic type disc and is more grabby holds about 1000hp and is great for spray/kitt turbo boost,fnf supercharger power. i wouldn't really like it for a daily driver. the rst is okay for daily driving.
now to answer the op's question. edit your title and take out the "ls7" part lol
here are the links for your enjoyment. as a matter of fact, everyone's enjoyment.
mcleod rst
http://www.coloradospeed.com/mcleod-...gt-p-7061.html
mcleod rxt
http://www.coloradospeed.com/mcleod-...gt-p-7384.html
run a steel fw, not a aluminum one
http://www.coloradospeed.com/mcleod-...ls-p-6543.html
on a corvette since they are light and it is a street car, you want a steel fw. if you road race which you don't, then you would get a aluminum flywheel because you want the flywheel lighter in that case.
if you have around 20-40k miles on the current setup, get a new slave cylinder. don't worry about a new master cylinder, the stock ones on the z06 are excellent and you don't need an adjustable m/c neither.
don't forget to get new fw bolts, a new pilot bearing and again, a new slave if it is needed.
PM coSPEED2 above to get your order going and he'll get you the pricing on the accessories bs you need. you can paypal or use a cc. just message coSPEED2
mcleod rst
mcleod rxt
too many people want to buy a 800 dollar clutch and reuse a high mileage stock flywheel and then bitch and whine the clutch is toasted.
this guy here is smart. he paid to play and got the billet steel flywheel and called it the day. his attitude of "do it once" is right. DO IT ONCE AND PAY ONCE OR DO IT WRONG AND PAY TWICE.
As a low skill consumer of auto parts, it took me a long time to select a replacement clutch, so I always enjoy when others have a favorable opinion about my selection, the RST with a steel flywheel of the same brand.
It can , infrequently, rattle a little at idle, but drives well on my stocker. I can modulate the clutch to just chirp the tires a bit when all eyes are on me at take off.
^ be prepared to hear it was from "improper install" or you didnt "shim it" etc etc.
yes. always buy a new billet flywheel. DO NOT reuse your old stock iron nodular flywheel by "resurfacing" it. it will not dissapate heat as well and will warp faster. think of the "resurfacing" of brake rotors analogy.
The Mcleod will be fine. His rant was in reference to the stock iron flywheel. The mcleod are one of the best out there. I would feel confident in running it machined as long as it is in spec after.
