did I order correct fluids?
just got back from GM dealer but guy at parts was not making me feel good that he knew his job.
1999 C5 6 spd
I got
89021183 (1L) Power Steering Fluid AC DELCO
6-spd Transmission Fluid 88861800 U.S. (88861801 Canada) AC DELCO
Rear Diff 89021678 AC DELCO
Coolant 109534464 AC DELCO DEX-COOL
1999 C5 6 spd
I got
I recently changed my Differential Fluid and Power Steering fluid on my 98 Auto.
Heres what I used:
AC Delco 12345867 Power Steering fluid (listed in owners manual/ordered through Amazon)
For the Differential I went with Amsoil 75W-90 Severe Gear(ordered through Amsoil website) You will need 2 quarts for Diff. and it also contains the slip lock additive already mixed in it. 300 miles since the fluid change and I'm happy.
As for the Coolant I'm pretty sure you have to use the Dex-Cool brand. I'm not sure about the Trans fluid part number you posted. I'd suggest check your owners manual for the recommended fluids.
Heres what I used:
Extract from a recent GM note:
"If fluid part number 88861800 U.S. (88861801 Canada) is unavailable when servicing a manual transmission or transfer case, Dexron III can be used in it's place. DO NOT use Dexron VI in place of the manual transmission fluid in any manual transmissions or transfer cases as a failure may result".
Says it better than I can - you ordered the right stuff for your transmission. You can, as GM says above, use a Dex III fluid (which was the factory fill when the car was built), but NOT Dex VI.
The confusion for all was caused by GM abandoning the Dex III standard for it's auto transmissions back in 2006, and moving to Dex VI.
And yes, these cars do run auto transmission fluid in their manual transmissions.
Personally, I am running Valvoline Dex/Merc which is labelled for pre-2007 GM vehicles. Got it from my local Advance Auto.
OK I did some more searching .
so here is what I found out
first off my owners manual calls for
1050017 1qt size
1052884 1pint size
if you use
10953471 946ml this is correct for corvette but designed for cold climates.
these are us part numbers.
for me in Canada we use
89021183 1L size
89021184 500ml size
1050017 1qt size
1052884 1pint size
if you use
89021183 1L size
89021184 500ml size
great thank you so now we confirms the usa.canada part numbers changes.
Premium Supporting Vendor
Those all look correct to me.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
