Help needed asap! Run rough, sounds like I installes flow masters!!
I was driving on the freeway when all of the sudden the car sounded a little louder. When I give it gas its like I installed a new exhaust. It almost sounds like the exhaust Is disconnected. Loud and burly. Car is running rough at the same time. I'm about 30 miles from home, I don't know what the problem is, maybe a cat? Can I drive the thing home?
Depends where the noise is coming from.
If its from the tailpipe, then pretty good chance you blew a cat (assuming you're running cats). If the exhaust is loud from the engine bay or anywhere underneath it could be a blown gasket.
