OEM rocker compatability between 243 vs 317
Does anyone know if factory LS1/6 rockers will work on 317 heads?
I just bought a trunion kit for my rockers but now i'm thinking i want to run 317 heads for my SC build. The 317 heads don't have rockers with them.
Will my rockers work or am I stuck having to buy truck rockers that were meant for the 317 heads?
Thanks.
Thanks.
Received 1,261 Likes
pretty sure they are all the same unless they are offset like the intake rockers on ls3/7/9's... is there a reason you want to use the 317 over the 243 besides the drop in compression?
you can still run some boost on 243's... if you have a cam that might bleed off some of the compression anyway and you could use meth as a safety measure or to make even more power
Yea I plan on going straight to a 3.4 pulley and running E85. No cam till I have to rebuild the bottom. Which could be yrs or on the dyno! lol...
stock block?... what other mods do you have?... I saw 12psi on my stock block and after I get done with a few more mods should see about 15psi... make sure you have a good tuner and that makes a lot of difference in how long it can live afterwards
yep stock LS1. Just LT's and a LS6 mani for mods besides the valvetrain parts i'll be adding to the 317s. Plan is to redo the stock fuel system with E85 components and then run a UPP secondary fuel system on boost.
Yea, I have a few options as far as tuners go in my neck of the woods.
I'm about the same, only other mod is a cam and meth but running e85 will have the same type of effect... you should have a pretty stout little setup
