Radio Flyer or Anyone assist with turn signal issue
Is there ever an issue with the DRL harness and flasher unit to cause turn signal to not work?
Driving to work, start the car up and entire driver's side DRL unit is dark. After driving a bit, DRL is on (thank you), but turn signal does not work. Rear turn signal works just fine.
So, the LED's are fine. Need to jump on this quickly, as Dallas traffic makes the turn signal your life saver.
DRL harness or something in the OEM system???
Does the DRL light go out when you put the turn signal on? Not at home with my DRL schematics now but will follow up later if no one beats me to it.
The DRL and turn signal are the same bulb filament or LED in your case.
I'm mentally thinking it could be the DRL relay. Might try swapping with the driver side one to see in the interim. If your problem moves you have your answer.
Good idea on swaping relays. At least eliminates one issue. Thanks!
Odd that when I first cranked up this AM, DRL was dead. Engaged headlights, and it came on. No turn signal, but they were on. Hmmm?!?!?
Light stays steady on when the left turn signal is used.
Ran the codes and I'm getting this:
28 TCS C1295H
40 BCM B2578
40 BCM B2583
I'm totally out of my league with this issue.
Couple of questions:
Did the DRL's LED's work properly at any time?
What happens when you take the DRL LED's out and replace them with the original halogen bulbs?
It's possible the IP light show is due to a defective LED bulb and possibly one or both of those bulbs are not the right ones to put into the DRL socket, don't ask how I know.
Try going back to stock halogen and see how that works.
Everything flashing sounds like the bulbs are in backwards.
The light or filament that illuminates when the headlights are on is not the same as the DRL.
My guess. The problem is either in the turn signal switch or the socket for the original bad DRL. You installed at least one backwards when you swapped sides.
I highly doubt it the harness. The flasher part is basically an all-or-nothing deal. If one side or even just one bulb flashes correctly then the power -> flasher -> turn signal switch parts is fine.
All's well that ends well.
Sent from my DROID TURBO XT1254 using IB AutoGroup
Glad you are back to normal. I suggest in the future you tell us everything you have done to modify the circuits we are trying to diagnosis. Otherwise we do not have all the information we need.
Glad you gotter done.
Agreed, sounds like the bulbs.
I had an issue with one of my RF bulbs going out shortly after my initial install. I replaced the bulbs with some from a retrosolutions. If you do have to purchase bulbs, make sure they are low profile. I initially purchased a pair from Amazon for cheap but they were too long to fit in the housing so I had to pick up another pair.
