Bad Wheel Hub?
Bad Wheel Hub?
I recently started getting a popping noise when slowly turning left into my alley (slight incline and not smooth) but not when making a normal left turn. I also heard a popping or banging noise when going over rough, bumpy roads. The noise sounds like it came from the front end and I could definitely feel something in the steering wheel when I went over the bumps. I figure it was suspension related and though it may very well be one of my front shocks as I replaced them last year and the top bolt wasn't easy to gauge the correct tightness and. I thought it's possible that the bolt slowly worked its way loose.
I lifted the car and checked all suspension components. I tightened down the front shocks more just in case I didn't have them tight enough and checked all the other bolts for sway bars, etc. Everything seemed to be nice and tight. I did the same for the rear as well.
I noticed that one of the rear wheels has some play at the 3 and 9 o'clock positions. I can push and pull and get some play. This does not occur on the other wheel and it also does not occur if my hands are at the 12 and 6 o'clock positions.
I took the car out for a spin and couldn't replicate the noise on my drive. So it's possible it was the front suspension but also I may not have found the right conditions. But after reading about bad hubs it sounds like they could possibly make the noises I'm describing.
Is the play at the 3 and 9 o'clock positions a sign of a bad wheel hub or could it be something else?
For 3 and 9 only, take a close look at the outer tie-rod end, or even the whole link.
HTH
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That was my very FIRST thoughts when you said you didn't have it at the 12-6 positions!
Thanks for the help. I won't be able to get to it until the weekend. If it is the tie rod will the movement be noticeable or will I have to remove any of the covers at the joints to see if they're bad? This will be my first time looking at tie rods so I'm not sure what I'm looking for.
Depends on how worn it may be.
"........will I have to remove any of the covers at the joints to see if they're bad?"
No. Easy to see and easy to replace. Alignment is necessary afterwards.
Okay, so I have a tiny bit of play near the boot on the outer tie rod end. So, I need to replace this but I cannot find this part anywhere.
The three major auto stores only carry the front tie rods and show nothing for the rears. All of the vendors I checked seem to not carry any or seem to be out of stock. Ecklers shows one but it has been discontinued. I can get the whole assembly from Gene but I'd rather not spend $100 if I only need the outer. Does anyone know where to get one or have a part number?
I looked some more and found the rears on Corvette Central. Would it be better to replace both ends at the same time to save on alignment costs or just the one since the other end could last years?
GM part # 88955488
SHOP AROUND. They're proud of them. gmpartseastdotcom (a GM dealer) has them for $80.91 ea.
HTH
If you want to save on alignment, count the turns when you unthread assemblies and use a tattle tale mark. Body shops do it this way, but use no tattle tale, they only align when they loose the starting point because of damage.
This will only return you to the original setting. I do know the right side usually wears faster, that is the side that rides in the gutter and deals with more torn up surfaces. Don't know about replacing just one side, ask a suspension guy.
