2004 w/ slotted-cross drilled rotors
Just bought a 2004 with slotted and cross drilled rotors. Was this stock in 2004? The car does have the Z51 package.
Jmohn
Jmohn
Great. Now I've got to figure out what I have before I need to buy pads. Although, I do think the calipers look stock so maybe not a problem.
Thanks,
jmohn
Thanks,
jmohn
Most likely they are aftermarket stock size.
I have run the brake motive ones with ceramic pads for > 3 yrs without any issue and I drive fairly spirited at times.
However if you are going to autocross or track it with repeated HS stops, Id look at something else.
