C5 heater core & evaporator core replacements...
Does anyone have a play by play and/or pix on replacing both the heater and evaporator cores on a 1999 ? I've got the instrument panel just about all the way torn down, but can't find all of the mounting bolts for the evaporator box on where to remove it. Also, does the intake have to come off in order to do the heater core replacement? Thanks in advance for any input!
nolaHacker (05-01-2023)
Have you removed the dash pad? If not here is the info. Easy DIY job, just bag and tag all your fasteners.
http://tech.corvettecentral.com/2013...-dash-removal/
Yes, I've already got the dash and all gauges out, including the pass side air bag. I'm down the the short hairs now, in how to get the evaporator box assy out. And also I heard you have to remove the engine's intake before being able to R&R the heater core. So my questions are is there a play by play for removing the evaporator core, as well as the heater core? Thanks.
The info is in the FSM but typically links from someone who has documented it is easier to understand or better when used in conjunction with the FSM.
For your viewing pleasure I just made a copy of the 1999 FSM section on the replacement of each.
They are PDF files so if you PM me with your email I will send them to you.
I have not tried to do any serious internet searches but if you do it using Goggle or another search engine you should get something also. I would start with C5 Corvette Heater Core, etc.
I didn't get any good hits on the heater but see if this helps. You may want to look harder than I did.
https://www.corvetteforum.com/forums...placement.html
Mr. Sam
Mr. Sam
