Testing OPS wires
Old 04-18-2015, 02:29 PM
nullpointer
nullpointer's Avatar
Default Testing OPS wires
I am trouble shooting a 0 oil pressure issue with my 02 Z06. Yesterday the oil pressure was fine, today 0.
Replaced the oil filter and OPS with no results. I want to test the wires leading to the OPS to rule this out next.
Its a 3 wire connector, ground, 5v, and voltage from sending unit correct?
http://farm4.static.flickr.com/3486/...1f98b5d9_b.jpg
I tested the ground, its ok.
Next I would attach my meter to the ground and grey wire, key to accesory and I should see 5 volts, right?
Old 04-18-2015, 03:26 PM
nullpointer
Key On - Grey wire has 5 volts - this is good
Key On - Tan wire has 0 volts - this is good
Ground is good
Tested OPS with compressed air and key on - Gauge moved
Looks like my pump is the cause
Old 04-18-2015, 03:47 PM
IH8FORD
IH8FORD's Avatar
i wouold be checking the o ring at pump didnt you just put a cam in when doing the supercharger? ive seen the o ring get torn or move out of place many times.
Old 04-18-2015, 04:16 PM
nullpointer
Yep - but the pump made great pressure for 2 days. I'll order a new pump and when I tear it down the o-ring will be looked at. If I don't need the pump I can return it.
To Testing OPS wires
Quick Reply: Testing OPS wires
