Trans fuse
As far as specifically called out fuses in the SM, Minifuse 21 in the passenger footwell fuse panel is for the Automatic Shift Lock Control System and inside rearview mirror.
http://redshift.homestead.com/files/c5-fuse.pdf
Best to look at the schematics to see where the harness is routed through.
Thanks Patches
I found # 21 and then #5 under the hood
Im having tansmission issues after a PCM swap and wanted to check to make sure it wasn't a simple fuse, but didn't know if it has a fused power source.
Thanks again
Thanks again
I swapped the PCM, downloaded (and purchased) the tune in the new PCM, then proceeded to change all of the tables to match my old tune. Several people have looked at it, but have not found an issue in the tune.
That is a stunning 98 by the way....
