Squeaky CoilOvers ?
Old 04-23-2015, 11:01 PM
BLEKVET
BLEKVET's Avatar
Default Squeaky CoilOvers ?
I posted a while back, but never resolved the problem. Responses indicated sway bar bushings - could still be the case. I had a tech look at the car, and he says it's the Pfadt CoilOvers making all the racket.
I don't think I agree, wholly, but want some opinions.
The car is a 2003 Z with coilovers. It swears and moans over EVERY LITTLE PAVEMENT inflection. It even moans when I get in and out of the car. I'm 30 pounds overweight, ideally, but Dayum.
Is it really the coilovers ?
Old 04-23-2015, 11:22 PM
racebum
racebum's Avatar
impossible to say on a forum. you need to change things and listen and or move parts and listen for noises
Old 04-24-2015, 01:03 AM
Last C5
Last C5's Avatar
I have seen a set of Pfadts squeaking/groaning because one of the little thrust washers on top of the spring was broke. Replaced it and all was quiet again.
Old 04-24-2015, 08:49 AM
BLEKVET
BLEKVET's Avatar
Thanks for the heads up. I will check this out !
Old 04-24-2015, 09:02 AM
bumble-z
bumble-z's Avatar
BLEKVET, are you running First Generation or the newer Inverted/Featherlight?
To Squeaky CoilOvers ?
Quick Reply: Squeaky CoilOvers ?
