98c5/a4 overheating
98c5/a4 overheating
So i just got the Tranny replaced and Im test driving it and next thing I know its overheating, Its fine when im going normal speed,but as soon as I stop at a light or some traffic, It jumps up to 240-to red zone. I have changed the thermostat, No Trash in radiator, and did a Radiator flush(although the coolant looked just fine), but still keeps overheating!! any other suggestions on what to do?? thx
Are the fans kicking on? And are you sure you don't have AIR in your system?
only 1 fan seems to be coming on around 235.. high speed. Hoses are fine when cold(no collapse). No air in system,unless im doing something wrong..
I can be idiling after it reaches 220 and it just goes up from there..
the car has been sitting for about 2 years! only starting it maybe once a week.. not sure if that has anything to do with it..
I have checked fuses, but not sure how to check relays!
Thanks for the Diagram!!
you sure the water pump is circulating the coolant?
If the passenger side is running at high speed then I would check relay 45. You can try swapping it with relay 43 which is identical. If the fan on the drivers side now runs the problem is the relay. Continue below if there is NO CHANGE.
I would also get the car up in the air so you can check the physical condition of the drivers side fan ( CAR NOT RUNNING). It may have ingested a plastic bag or the fan blade may be missing or the motor frozen.
The fans on the C5 are wired in series for low speed operation and the relays switch the wiring to parallel for high speed operation. You can also check the operation of the fans with the AC on and they should go into low speed operation (both fans running) at about 185 degrees coolant temp.....
I suggest starting with the easy to check items like fuses and relays and physical condition of the fans and wait until they have been eliminated to focus on something that requires more effort such as water pump. JMHO
Funny... after saying that I'm not sure either... use to we would just leave the cap off the radiator and when the thermostat opened you could see the coolant begin to circulate.. I don't know if that will work with the cap off of the purge tank?
Ok.. I went to the shop, started our car with the purge cap off and let it get up to operating temp... saw no sign of circulation in the tank... so I guess that won't work. They should put a section of clear hose or something so you can see circulation in your cooling system... dang it!
Do both fans come together as 1 unit, or can i just purchase the one that isnt working? Let me also ask---It should have come on by the time it reached 250 degrees correct?
I know it's a long read... but worth the time. Copy and paste it for your C5 file
Cooling System Description and Operation
Cooling Fan Control
The engine cooling fan system consists of two electrical cooling fans and three fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage and ignition 1 voltage from the underhood electrical center. The ground path is provided at G102.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 3 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan 3 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 3 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Engine Coolant Indicator(s)
COOLANT OVER TEMP
The IPC illuminates the COOLANT OVER TEMP indicator in the message center when the following occurs:
The PCM detects that the engine coolant temperature exceeds 124°C (256°F). The IPC receives a class 2 message from the PCM indicating the high coolant temperature.
The IPC will also illuminate the CHECK GAGES indicator and a chime sounds when this condition exists.
Cooling System
The cooling system's function is to maintain an efficient engine operating temperature during all engine speeds and operating conditions. The cooling system is designed to remove approximately one-third of the heat produced by the burning of the air-fuel mixture. When the engine is cold, the system cools slowly or not at all. This allows the engine to warm quickly.
Cooling Cycle
Coolant is drawn from the radiator outlet and into the water pump inlet by the water pump. Some coolant will then be pumped from the water pump, to the heater core, then back to the water pump. This provides the passenger compartment with heat and defrost.
Coolant is also pumped through the water pump outlet and into the engine block. In the engine block, the coolant circulates through the water jackets surrounding the cylinders where it absorbs heat.
The coolant is then forced through the cylinder head gasket openings and into the cylinder heads. In the cylinder heads, the coolant flows through the water jackets surrounding the combustion chambers and valve seats, where it absorbs additional heat.
Coolant is also directed to the throttle body. There it circulates through passages in the casting. During initial start up, the coolant assists in warming the throttle body. During normal operating temperatures, the coolant assists in keeping the throttle body cool.
From the cylinder heads, the coolant is then forced to the thermostat. The flow of coolant will either be stopped at the thermostat until the engine is warmed, or it will flow through the thermostat and into the radiator where it is cooled and the coolant cycle is completed.
Operation of the cooling system requires proper functioning of all cooling system components. The cooling system consists of the following components:
Coolant
The engine coolant is a solution made up of a 50-50 mixture of DEX-COOL and clean drinkable water. The coolant solution carries excess heat away from the engine to the radiator, where the heat is dissipated to the atmosphere.
Radiator
The radiator is a heat exchanger. It consists of a core and two tanks. The aluminum core is a crossflow tube and fin design. This is a series of tubes that extend side to side from the inlet tank to the outlet tank. Fins are placed around the outside of the tubes to improve heat transfer from the coolant to the atmosphere. The inlet and outlet tanks are molded with a high temperature, nylon reinforced plastic. A high temperature rubber gasket seals the tank flange edge. The tanks are clamped to the core with clinch tabs. The tabs are part of the aluminum header at each end of the core. The radiator also has a drain **** which is located in the bottom of the left hand tank. The drain **** includes the drain **** and drain **** seal.
The radiator removes heat from the coolant passing through it. The fins on the core absorb heat from the coolant passing through the tubes. As air passes between the fins, it absorbs heat and cools the coolant.
During vehicle use, the coolant heats and expands. The coolant that is displaced by this expansion flows into the surge tank. As the coolant circulates, air is allowed to exit. This is an advantage to the cooling system. Coolant without bubbles absorbs heat much better than coolant with bubbles.
Pressure Cap
The pressure cap is a cap that seals and pressurizes the cooling system. It contains a blow off or pressure valve and a vacuum or atmospheric valve. The pressure valve is held against its seat by a spring of predetermined strength, which protects the radiator by relieving pressure if it exceeds 15 psi. The vacuum valve is held against its seat by a spring, which permits opening of the valve to relieve vacuum created in the cooling system as it cools off. The vacuum, if not relieved, might cause the radiator to collapse.
The pressure cap allows pressure in the cooling system to build up. As the pressure builds, the boiling point of the coolant goes up as well. Therefore, the coolant can be safely run at a temperature much higher than the boiling point of the coolant at atmospheric pressure. The hotter the coolant is, the faster the heat moves from the radiator to the cooler, passing air. The pressure in the cooling system can get too high, however. When the pressure exceeds the strength of the spring, it raises the pressure valve so that the excess pressure can escape. As the engine cools down, the temperature of the coolant drops and a vacuum is created in the cooling system. This vacuum causes the vacuum valve to open, allowing outside air into the cooling system. This equalizes the pressure in the cooling system with atmospheric pressure, preventing the radiator from collapsing.
Surge Tank
The surge tank is a plastic tank with a pressure cap mounted to it. The tank is mounted at a point higher than all other coolant passages. The surge tank provides an air space in the cooling system. The air space allows the coolant to expand and contract. The surge tank also provides a coolant fill point and a central air bleed location.
Air Baffles and Seals
The cooling system uses deflectors, air baffles and air seals to increase system cooling. Deflectors are installed under the vehicle to redirect airflow beneath the vehicle to flow through the radiator and increase cooling. Air baffles are also used to direct airflow into the radiator and increase cooling. Air seals prevent air from bypassing the radiator and A/C condenser. Air seals also prevent recirculation of the air for better hot weather cooling and A/C condenser performance.
Water Pump
The water pump is a centrifugal vane impeller type pump. The pump consists of a housing with coolant inlet and outlet passages and an impeller. The impeller is a flat plate mounted on the pump shaft with a series of flat or curved blades or vanes. When the impeller rotates, the coolant between the vanes is thrown outward by centrifugal force. The impeller shaft is supported by one or more sealed bearings. These sealed bearings never need to be lubricated. With a sealed bearing, grease cannot leak out, and dirt and water cannot get in.
The purpose of the water pump is to circulate coolant throughout the cooling system. The water pump is driven by the crankshaft via the drive belt.
Thermostat
The thermostat is a coolant flow control component. It's purpose is to regulate the operating temperature of the engine. It utilizes a temperature sensitive wax-pellet element. The element connects to a valve through a piston. When the element is heated, it expands and exerts pressure against a rubber diaphragm. This pressure forces the valve to open. As the element is cooled, it contracts. This contraction allows a spring to push the valve closed.
When the coolant temperature is below 91°C (195°F), the thermostat valve remains closed. This prevents circulation of the coolant to the radiator and allows the engine to warm up quickly. After the coolant temperature reaches 91°C (195°F), the thermostat valve will open. The coolant is then allowed to circulate through the thermostat to the radiator where the engine heat is dissipated to the atmosphere. The thermostat also provides a restriction in the cooling system, even after it has opened. This restriction creates a pressure difference which prevents cavitation at the water pump and forces coolant to circulate through the engine block.
Transmission Oil Cooler
The transmission oil cooler is a heat exchanger. It is located inside the right side end tank of the radiator. The transmission fluid temperature is regulated by the temperature of the engine coolant that surrounds the oil cooler as the transmission fluid passes down through the cooler.
The transmission oil pump, pumps the fluid through the transmission oil cooler feed line to the oil cooler. The fluid then flows down through the cooler while the engine coolant absorbs heat from the fluid. The fluid is then pumped through the transmission oil cooler return line, to the transmission.
Coolant Heater
The optional engine coolant heater (RPO K05) is rated at 400 watts and supplies 1365 btu/hr. The engine coolant heater operates using 110-volt AC external power and is designed to warm the coolant in the engine block area for improved starting in very cold weather -29°C (-20°F). The coolant heater helps reduce fuel consumption when a cold engine is warming up. The unit is equipped with a detachable AC power cord. A weather shield on the cord is provided to protect the plug when not in use.
Cooling Fan Control
COOLANT OVER TEMP
Cooling System
Cooling Cycle
Coolant
Radiator
Pressure Cap
Surge Tank
Water Pump
Thermostat
Coolant Heater
You should be able to purchase a single fan motor. I would get the front of the car up n jack stands and examine the motor and the fan blade. They are purchased separately so if you buy a new motor you either need to reuse the old blade or purchase a new one. Before you purchase anything make certain there is nothing (plastic bag are common) jamming the fan blade/motor.
Yes BOTH the fans come on together and by 250 degrees they should have BOTH been running in high speed mode.
Check for debris in the radiator fins carefully. Not just big "chunks" but dirt and small stones that block air flow. Best way is to remove the radiator so you can use a gardwn hose to wash debris from the back side to the front. Going front side to back will just lodge the debris further into the cooling fins.
and has anyone ever changed this fan out? Not sure if I have to take the radiator out first!
I think maybe I should take it somewhere and have the fan tested first.. although i already know its not coming on at all.
Cooling Fan Control
COOLANT OVER TEMP
Cooling System
Cooling Cycle
Coolant
Radiator
Pressure Cap
Surge Tank
Water Pump
Thermostat
Coolant Heater
Cooling Fan Control
COOLANT OVER TEMP
Cooling System
Cooling Cycle
Coolant
Radiator
Pressure Cap
Surge Tank
Water Pump
Thermostat
Coolant Heater
Helps us help you... Still overheating... be specific, were you driving, idling? Review what you've done and let's go from there...
Well, I got it back today and drove it about 5 miles, the temp was at 220 steady.. so i pulled over to see if the drivers side fan was coming on, it was not.. so while sitting there idling the temp started to rise! 230,240,250. then i shut it off.. no trash in radiator, i have changed the thermos stat, and flushed it 3 times, put the proper fluids back in it.. the passenger side fan is blowing just fine. Im just thinking, how damn hot does it have to be for that drivers fan to come on!! One guy at the shop was saying thats just an "AC" fan!! I dont even have AC! Even when i shut it off neither fan stays on @250.. i could have sworn before i used to hear the fans running when i shut it off atleast.. what am i missing on how the fans work? I would think the drivers side should come on before 220 and then the passenger side kick on after that! any thoughts would be greatly appreciated!
