03 120K miles = little jiggle in the front end with a bump
Guys
have an 03 120K miles all original - been getting a little jiggle in the front end when hitting a bump !!
seems like a tierod end or such but checked and they are fine - jacked up both sides and wiggled the tire top and sides all seem tight -
anything else that could be out?
tires are wearing ok so dont think a hub...
any suggestions appreciated!
St. Jude Donor '15
When's the last time you had an alignment done? Could have a worn control arm bushing.
Could also be a bad shock. Had a friend's truck jerk left/right when he hit a dip in road. Ended up being a blown shock that was binding.
Signed - the alignment guy
I guess really all that ya have in the front on each side is two ball joints ,
a tie rod end , sway bar links and bushings - not much else to go bad
