1282 h c code after radio install?
Says it is a yaw rate sensor issue,
I tested voltage at the connector for the sensor,
Grey=9.01 volts
other 2 nothing
I believe the voltage shouldn't be over 5 am I correct?
If so what would cause this?
info center flashing service active handling
corvette is a 2001 coupe
Grey=9.01 volts
other 2 nothing
Moderator, Tech Contributor
Received 2,119 Likes
Please start a new thread with what you are seeing and any DTC’s too…also fill out your personal profile with model year (your profile shows a 1979), mods, etc…
