C5 oil pressure switch bad?
suddenly my oil pressure gauge is reading 80 psi. it is also like this with the engine off but key on. it normally is about 40 or so with engine running. oil level is correct. i am guessing it is bad. just want other opinions. also where is it located?
thanks in advance for the replies.
Common problem, the sensor is located in back of the intake manifold. Couple different ways to replace it lots of threads on it
https://www.corvetteforum.com/forums/c5-tech/1817090-updated-again-8-25-13-ultimate-diy-faq-thread-it-s-all-in-here.html
Post number 73
Post number 73
Yup bad OPS... replace/relocate
1 take it to a professional have it replaced.
2 replace it yourself.
Methods
The SNEAK in there and get it method
The REMOVE the intake method...
The Access hole in the wiper tray method...
Had a hard time find good info on this method....weird, been lots of post on it, and it can be done neatly... this isn't the best link, but gives you an idea of what can be done...
https://www.corvetteforum.com/forums...placement.html
Relocation is recommended with any method... the OPS lives in a very unfriendly environment and will be happier when relocated.
https://www.corvetteforum.com/forums...c5-oil-sender-
Methods
My wife and I pulled the manifold and did mine twice. I found the wiring harness from the factory was short and putting a lot of stress on the top of the sender. I did an F15 wiring repair and put a stress relief loop in the harness so there is no tension on the unit and it has worked great since then. WARNING use OEM replacement part on this. I ordered one and it was missing the gasket so I went bought napa part and installed, Wow was the pressure reading off, might be ok for a truck. I put OEM back on and it was exact pressure
Which ever method you choose to replace your OPS... I would still highly recommend relocating it... it will live a long and productive life!
I would take the extra time and do the relocation, will make the next time you change it a snap, and trust me it will happen again.
https://www.corvetteforum.com/forums...post1562145914
I did the relocation and used the buick sender part # 12584940 and have had no problems.
the ac delco sensor is fine, but, the borg warner one orileys sells has also proven to be very reliable
The key to longevity is to not over torque the new one.
IIRC the spec if 15 ft-lbs.... take it to that level in 3 steps.....
10, 12,15....
My replacement lasted over 40K (s)miles in my '01 before I sold it.
10, 12,15....
Looks nice... good decision!
ok, i got the new switch. i read and watched the videos you guys posted. i removed the plastic covers and still can't see the switch let alone touch/reach it. i don't want to remove the intake to do this. can i remove the wiper cover somehow to get to the switch? btw, this is still the original switch that is bad at 120K miles.
thanks a lot.
thanks a lot.
1 Post
It is very tight back there. Many people cant get to it as is so they CUT a hole in the wiper tray. I wouldnt hack my car like that. I removed the intake manifold and replaced the gaskets while I had it off. It is an easy job to do.
Bottom line it is all in what you feel comfortable doing. The folks here give excellent advice and can help you through any repair you need to do. Some are professional car guys and others are hobbyists. It is all in what you are comfortable in doing and how much you want to stretch in you mechanical comfort zone.
Good Luck
Cutting an access hole under the wiper cowl cover... doesn't have to be a "hack" job, it can be done neatly and then sealed up nicely... the wiper cowling covers it anyway and unless you REALLY look for it you'll never know it was ever done...whatever method you use to or have the OPS replaced it's a GOOD idea to RELOCATE... it LIVES in a VERY Hostile environment and will live longer in a new cooler location.
