I think I broke my differential
After a hard 1st to 2nd shift, I'm having some really bad clunking/bucking from the rear when I start off in from a stop. Once I get up to speed it ok *** long as I don't press the gas to hard. Sound like a rear diff?
Ok, I got the car in the air and took the tires off just to get a good visual. Everything looks fine and no fluids are coming out. However, if I spin one rotor the other does not spin. Isn't the other side supposed to spin too? Maybe one of the outputs broke?
Cruise-In IX Veteran
How bad is the clunk? When I had symptoms like you are describing it was because I sheared the cross pin in the differential into 3 pieces. The posi ate itself from the inside after that.
I would rate the clunk at "brutal". I limped it home but if I gave it more than 5% throttle, it would clunk so hard that is shook the car.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You either broke the cross shaft spider gear/s OR busted an output shaft.
You have to remove the differential either way... Here are some post for you to read and they will give you some ideas and may some upgrades on the cheep:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Yup...sounds like mine when it went. Clutch packs broke and a gear was stripped. Rpm is the best at rebuilding them. Stage 3 different for sure, and if you don't have it, a dts brace.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Another option for differential service is
RKT56.com
Rick Kim does EXELLENT work and will build the differential to any level that you want.
Excellent service
Once you get it out of the car, you will be able to diagnose it better
Bill
RKT56.com
Excellent service
Bill
Update
Got the differential apart today. Cross shaft is good but the spider gears are chewed up and the clutch preload springs were broken. Clutch packs and springs were so messed up I didnt even need a special tool to remove the cross shaft. Just pushed right out with my fingers. There were two pieces of preload spring left that made about 3/4 of a circle on the long shaft side and just on piece that was about 1/3 of a cirlce on the other. The discs are REALLY worn too. Should have had that changed a long time ago. I suspect the preload springs broke and started havoc with the spider gears.
One question though. The inside of the differential where all the spider gears and such are, the walls are a little marred in places. Would this affect anything on a rebuild?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
RPM sells a harder and better designed cross shaft. I also installed one of those:
New shaft on the left:
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sometimes we take the C5 differential for granted. Its NOT a typical GM diferential. To replace the pinion carrier, the ring and pinion or any of the bearings, you have to have the rearend properly set up using the correct shims and set up tool that is required to do the job correctly.
Sometimes, the basic "fix whats wrong and move on" is whats necessary. Just didnt want the OP to think that just anyone can slap in a ring and pinion and move on.. Its NOT happening..
Bill
Bill
Yeah, just reading about changing the ring and pinion makes me sweat lol. So what is the best way to clean all the fluid off of the differential parts (Like any particular solvent).
Also, does anyone have part numbers for all of the differential internals. I found cluctch pack/spring part numbers but I don't know about spider gears or any other pieces that may need replacing?
Huge thanks for the help so far!!
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Two places that I know will be able to help you out:
Gene Culley If its GM and available OEM, he will have it. Give him a call.
https://www.corvetteforum.com/forums...kend-sale.html
Rick Kim RKT56.com He can get any differential parts as he rebuilds differentials and transmissions.
