OBX long tube headers install/review
A few more quick notes. I did NOT remove the spark plugs, plenty of room there. I DID replace the front o2 sensors with the rears for the longer wires, since the forward most o2 bungs are now in the collectors, some 30 extra inches away from stock. I used a couple of drain plugs from a Honda car that I got from Napa for $8 to plug my rear o2 holes, and am currently just running fronts. After about 100 miles, i tripped a code, but the car is running just fine still, so I'm not too worried about it, after doing the research about it ahead of time. I said I was going to post the part number on those plugs, but I tossed the bag, and lost the URL to where I found it But I did find it here on this forum, soooo...happy searching It is perfectly possible to have a tuner, tune out your rear o2's, you don't need them, and you can pass emissions without them (important, since I'm running catless). You can also MAKE 02 simulators, a process I will outline later...when I actually do it.
Alright, I think that is all. If you have any questions go ahead and post them here, and I'll help the best I can
Now, off to make a Youtube account so I can post before, and after sound clips!
well youtube is not as easy to set up as it's cracked up to be, so here is the link to my photobucket.
This is before headers, car has a flowmaster catback, that has had the muffler bypass mod done to it. http://s272.photobucket.com/user/eri...tml?sort=3&o=7
And THIS is after the headers
http://s272.photobucket.com/user/eri...tml?sort=3&o=0
enjoy!
enjoy!
Dyno numbers after my tune. This dyno is stingy, I baselined before any mods at 273whp on this dyno, and 290whp on a mustang dyno for reference. Car has the rams horn dual cone intake and flowmaster mufflers that have been bypassed, no cats, and it's an 01 A4
Nice gains
Thanks I think I'm leavin' some hp on the table with the cheapo intake, but I should get a bit of a bump out of the Honker I'm putting in today, then a ported throttle body, a coolant bypass, and a touch up tune before I make the leap into a TPiS modified ls6 intake with a 90mm throttle body. I want to hit 350whp via bolt ons before I put a stall in it.
Awesome write up. I'm about to buy these headers for my vette. It looks like you have the catless resonator kit? Does your set up sound raspy at all? I can't decide if I want the kit with the cats or with the resonators... I have the raspiness of my stock system minus the cats but I don't know if that raspiness will come over using the obx system.
If im hard on the gas, but not quite enough to make it kick down a gear automatically, it will rasp out during the shift from 1-2 gear, other than that its just loud, but my mufflers have been bypassed as well. It is very quiet on the freeway.
